Compression?
Old Oct 23, 2007 | 12:50 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Compression?
For forced indiction applications, I've read it's a good idea to start with a low compression engine to safely use more boost. What compression are you guys running with what boost?
Old Oct 23, 2007 | 05:54 PM
chriswtx's Avatar
chriswtx
9.5/1 w/Paxton Novi 2000 making 15-18psi of boost...
Old Oct 23, 2007 | 06:52 PM
blu00rdstr's Avatar
blu00rdstr
Be careful how low you go. Too little compression means you need to make lots more boost, which needs a better belt/pulley/bracket setup. It also makes it feel softer at lower rpm and the bigger belt load means more power is consumed to make power.
You can make tons of power at 8.5:1cr, but it's much less work to make the same power at 9.5:1cr. Conversely boost can add power to a 10.5:1cr motor, but it can add much more to a 9.5:1cr motor.
I think 9-9.5:1 is probably about right for a high-hp motor.
Old Oct 23, 2007 | 08:51 PM
Vega$Vette's Avatar
Vega$Vette
10.9:1 with a Maggie at 5.2 psi boost.
Old Oct 23, 2007 | 10:24 PM
badc51's Avatar
badc51
Default boost
10.8 9lbs boost 575/525 383 A4 A&A kit, great throttle response.
Old Oct 23, 2007 | 11:52 PM
master blaster's Avatar
master blaster
what if my car is at 4500ft elevation? I was told to go 1 point higher then sea level. I am thinking of building my motor for my STS setup but feel I will go back to a supercharger down the road....because I like a loud exhaust. 15-18# is my goal.
Old Oct 24, 2007 | 12:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
6.8 LBS B@@ST ProCharger 3.85" Pulley on 10.9:1 64cc TFS Heads!
Thanks,Matt
Old Oct 25, 2007 | 11:03 PM
master blaster
Old Oct 25, 2007 | 11:41 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Yes the norm is to run between 9:0 to 9:5 to 1 compression for must supercharged applications. However, you can run higher compression if tuned right and if the motor can handle it, and just like my stock LS6 motor that has 10:5 to 1 compression (and 11,700 trouble free miles) my forged LS6 blower motor being built, will also be 10:5 to 1, as this will make BIG POWER with less boost, and CRAZY power with the 12 lbs of boost I expect to run (should make 700rwhp) and the mid range power will be outstanding also, as well as the responsivnes of the the car off the boost, stop light to stop light!
Old Oct 26, 2007 | 12:14 AM
2004SpiralGrey's Avatar
2004SpiralGrey
9.7:1CR, 383ci, 8 psi, 605rwhp/540rwtq, built by me and tuned by ECS
Old Oct 26, 2007 | 11:30 AM
PRAY's Avatar
PRAY
Low compression will give you a soft bottom end just driving around. I think Dynamic compression should be more of a consideration. I run 12.0:1 compression on my NA motor. My cam is so large with a wide lobe seperation that I only have 8.6:1 DCR. The car runs fine on 93 octane in 101* humid heat. On my next SC car I am going to run the same cam and probably around 10.0-10.5:1. I am willing to bet my DCR will actually be much lower than my LS6 motor with a 224/228 cam that I ran at 10psi on my stock motor. I may actually find out what the DCR was on the LS6 motor and adjust my compression ratio to match it. Now that I am forged I will run 12-14lbs of boost.
Old Oct 26, 2007 | 12:38 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
You know I hear this alot and am yet to see it play out on the Vette's in practice.
I have now built a 347, a 382, and a 427 with TT's on it. All of these motors are right about 8.8:1 compression and NONE of them are soft on the bottom end.
Also have a 416 in the works. I think it is too general of a statement to say that with a low compression motor the power will be soft down low, IMO. My real world experience tells me otherwise. These are all well over 700 HP setups.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Oct 26, 2007 | 07:29 PM
PRAY's Avatar
PRAY
That is awsome that you have your combos dialed in like that. Maybe I sould have said, softer than if you had some compression. I think it also depends on the cam and dynamic compression like I stated above.
Compression will give you better gas milage, throttle response, and power. What happend in the 70's when we went to low compression motors? They were dogs. Horse power was dead. Now motors come from the factory with 11.0:1 and we are eons ahead of the 60's era cars in power. 90% of the time a S/C motor is not in boost. Only under WOT is boost introduced. So you are essentialy running a NA motor 90% of the time. A point of compression is worth about 14hp and a lb of boost is worth about 22hp. So why not run an extra point of compression to make the NA side of things happy and one or two less lbs of boost up top. Or put some meth on the thing and let it eat. If I was going to throw 25+lbs of boost at something then I would def opt for the high eights on compression. But the truth of it is that MOST people that boost a LS engine only go to 14-15lbs max. I would actually say that the majority never see over 12lbs. Just my opinion.
Here is something I just checked on. With my stock LS6 engine with a 224/228 .581/.588 114+4 the DCR comes to 8.41:1. I ran 10lbs of boost on this engine and made 635/550rw at 6,200rpm with a restrictor plate. Now with my new cam 244/248 .612/.615 114+4 it needs 11.6:1 SCR to get close to the same 8.42:1 DCR. So this cam with and 9.5:1 compression it would most def not have the same power down low or any where else for that matter. If I am running the same DCR, which is all the motor really sees any way, then what is the harm in running 11.6:1 SCR?
Old Oct 26, 2007 | 07:33 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
9:4:1 @ 15 psi
Old Oct 26, 2007 | 07:59 PM
Mopar Jimmy
St. Jude Donor '06
Compression will give you better gas milage, throttle response, and power. What happend in the 70's when we went to low compression motors? They were dogs. Horse power was dead. Now motors come from the factory with 11.0:1 and we are eons ahead of the 60's era cars in power. 90% of the time a S/C motor is not in boost. Only under WOT is boost intraduced. So you are essentialy running a NA motor 90% of the time. A point of compression is worth about 14hp and a lb of boost is worth about 22hp. So why not run an extra point of compression to make the NA side of things happy and one or two less lbs of boost up top. Or put some meth on the thing and let it eat. If I was going to throw 25+lbs of boost at some thing then I would def opt for the high eights on compression. But the truth of it is that MOST people that boost a LS engine only go to 14-15lbs max. I would actually say that the majority never see over 12lbs. Just my opinion.
I 100% and that is why I will be running around 10:5 to 1 compression on my forged LS6 motor that will see about 12 lbs of boost and should make BIG POWER on the boost, and be very responsive off the boost.
Also, here is a quote I saved from SLOWHAWK a well known and respected tuner here regarding compression as it relates to bigger cams and making good midrange power!
"Compression dictates Cam selection too.
Compression is key to making midrange power and with the bigger Cams the DCR lowers which makes it safe to run pump gas.
I would expect around 700hp on my dyno with this setup at 12lbs of boost."
Old Oct 26, 2007 | 08:07 PM
PRAY's Avatar
PRAY
I just edited my above post with some interesting information along the lines of what you just said. Give it a quick read.
Old Oct 26, 2007 | 08:09 PM
MotleyDrew's Avatar
MotleyDrew
9:6:1 14lbs right now
Old Oct 26, 2007 | 08:14 PM
RED99's Avatar
RED99
When I replaced my stock LS1 heads with some stock LQ9 heads with the 72cc chambers and changed nothing else and dropped my compression down to 9.6:1, I lost low end response, Max. power, and fuel milage. This is at 10 psi of boost on a maggie. So it does hurt power and fuel economy. The only advantage to run low compression is to run higher boost levels. If you are planning on running 15 lbs of boost, then I would think somewhere between 9:1 to 9.5:1 would be good. But the DCR from the cam timing will also play a part.
To Compression?
