Wet Kit - Insight
Old Oct 24, 2007 | 05:02 PM
obi05rp's Avatar
obi05rp
Default Wet Kit - Insight
how complete is the corvette wet kit from Nitro Dave? compared to the NX or NOS systems. What else will be needed after the fact?
http://www.nitrousoutlet.com/catalog...roduct_id=1133
who is running this kit and how is it? ease of install? etc
thanks
Old Oct 24, 2007 | 10:10 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Looks like the plate kit, I am running it (I went with the Lightning Noids for looks), worked right out of the box. I have not seen the instuction set (although I sent Dave pics of my install). Totally Stock I found the recommended jetting rich, once I added H/C the recommended jetting was Lean, so get some fuel jets for tuning as needed.
You can pretty much use the NOS Plate instructions for it (thats what I used for my install), they are readily available from the NOS site (Go to Holley drill down to NOS, then look for the LS1 kit instructions)...
As for kit completeness, you should add a window switch, a bottle heater, a purge, and TR-6 Spark Plugs.
Nice to have items include an bottle opener a C-5 Specific Switch panel for the ashtray.
Here is a Stock Dyno Jetting on the sheet Plate only Stock 99 LS1 (Base HP was 300 NA)
