KB BAP and nitrous
I was wondering if the KB can be wired to only activate when the nitrous arming switch is turned on? Is that possible?
The ARM switch is really not necessary if you just tied it to a WOT switch.
You can also get a vac switch from KB.
There are 100 ways you can do it. Just try to do it the simplest way possible.
The racetronix harness is the easiest way to hook in the BAP, but it has nothing to do with kicking it on. There are two other pairs of wires that come out of the BAP box.
1. The pair for the **** - you are going to cut the **** off and just solder these two wires together. This will guarantee you get 17.5 V everytime it activates and will ensure that you don't accidentally turn the **** down when you are done tuning and screw something up.
2. This the pair of wires that goes to the Hobbs switch. You can hook these to any switch. Anything.. WOT switch, Push button, anything. If you use a secondary device, i.e. a Window switch, I would use a relay to actually connect these two. So your WOT or Window switch would activate a relay which would connect these two wires together.
The only thing you DO NOT want to do is leave the BAP running all of the time. It is just not necessary and COULD shorten your pump life. you want it to activate somehow when you stand on the car.
Hope this helps... if not let me know, but you can get a switch from KB for a non-boosted application.
The only thing I saw that goes to the **** is one black wire that has a plug on it but I may have to look at it again.
I think I do have the N/A version though. Its brand new, never used but I bought it from another forum member and the part number that was on the reciept was the NA version. I hope Im not confusing you
If you send me the number off of the Hobbs switch I can tell you which one you have...And no you are not confusing me at all.
