Switching to Long Tubes
Old Nov 22, 2007 | 06:04 PM
hightest's Avatar
hightest
Default Switching to Long Tubes
Hi everyone,
I currently have the Vortech brand SC kit (SQ S-trim)on my 2000. It is pushing 5 lbs. on a basically stock LS1 with the LS6 intake, ported TB, Crane 1.8 rockers, and B&B coated shorties (currently 432 rwhp).
I plan on going to LT's and meth injection.
1) will the long tubes make a worthwhile increase over the B&B shorties, or will the increase be negligible?
2) Should the meth kit injector be placed prior to the IAT sensor, or directly into the TB like the A&A kits?
Thanks for any help.
Ted
Old Nov 22, 2007 | 06:51 PM
2004SpiralGrey's Avatar
2004SpiralGrey
With the LT headers you will lose a little more boost. What size pulley are you running?
1) It wil be a nice increase, shorties really don't do too much.
2) The meth kit should go after the MAF not before it.
Old Nov 22, 2007 | 08:16 PM
hightest's Avatar
hightest
Sorry guys, I meant the IAT not maf.
Old Nov 22, 2007 | 08:18 PM
hightest's Avatar
hightest
I haven't measured the pulley, it's the standard pulley that comes with the vortech kit. My boost guage is saying 5 lbs. at max boost.
About how much boost do you think I'll lose?
Old Nov 23, 2007 | 12:29 AM
2004SpiralGrey
I lost 4 lbs. when i went with lt headers. Let me know if you need a 3.6" Richard Racing Ultra grip pulley. It doesn't sound like you have the 3.6" pulley with those boost levels. With the 3.6" you should see about 8lbs. and with meth and a safe tune you should have somewhere around 540rwhp.
If you go with the LT's...Pulley down and run some meth. You'll have one mean street car
Old Nov 23, 2007 | 11:10 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by hightest
Hi everyone,
Ted
Hey Ted,
Your METH Kit should go in before the IAT sensor because it drops temperatures so much the IAT sensor will add timing and increase the HP!
Plus when you scan the IAT when you are tuning you can watch it decrease and the timing get bumped up!
If you do not then you will have the IAT at one temp (Hotter) than the actual intake charge!
As far as loosing the pounds of B@@ST w/ the addition of Headers I could not tell you, but what you can do is lookk at the responses and get a new pulley accordingly or install the headers and take a run and see where the B@@ST level is at and buy one accordingly!
Just don't run it too long with the headers that way becasue you are going to need a new tune as well as for the METH!
I have METH, Headers and a P1SC-1 ProCharger and I have a 3.85" Pulley and it is giving me 7.6 PSI of B@@ST!
Hope this helps!
Thanks,Matt
Old Nov 23, 2007 | 08:30 PM
hightest's Avatar
hightest
Thanks for all the replies!
I'll post exactly how much boost I drop after the header change, and I'll also post how much hp I gain after installing the LT's before the meth and pulley change.
Old Nov 23, 2007 | 08:52 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I would personally do a smaller blower pulley at the same time. Good luck
Old Nov 23, 2007 | 10:29 PM
hightest's Avatar
hightest
Yeah, the smaller pulley sounds like a good idea. I'll take the calipers and measure the existing pulley this weekend.
Old Nov 24, 2007 | 09:43 AM
Watch22's Avatar
Watch22
I run a 4.0" pulley on my stock LS6 with a A&A SQ-Trim, Long Tube Headers and see about 7.5PSI at 6500RPM. I also have the restrictor plate in.
Old Nov 24, 2007 | 05:26 PM
hightest's Avatar
hightest
I checked on the vortech pulley set-up, and their cogged pulleys are sized based on tooth count instead of diameter. My existing pulley is 32 teeth, I'm thinking that the 30 or 28 tooth count pulley should give me back around 4 lbs. of boost.
To Switching to Long Tubes
