nitrous question ...150 Shot
Old Nov 27, 2007 | 10:05 PM
Slovette2000's Avatar
Slovette2000
Default nitrous question ...150 Shot
Nitrous on a vette
Old Nov 27, 2007 | 10:20 PM
bgreen83's Avatar
bgreen83
I was wondering about this as well, well what is the best kit. what kind do you have?
Old Nov 27, 2007 | 10:34 PM
KamiLos's Avatar
KamiLos
my zex wet kit came in today. results will follow.
Old Nov 27, 2007 | 11:52 PM
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
Originally Posted by Slovette2000
99 FRC with exhaust and a air filter with 150 shot and a tune ...how fast will the car B ? the car trap 110 mph in the 1/4 Stock
would I b able to keep up with 500 / 550 rwhp terminators from a roll??? (at the track )
I got big plans for the car but at this moment this is the easiest and fastest way to b quick
I can answer that
on my stock ls6 (cartek clutch) with a 150 shot i ran 127 in the 1/4 11.51 ..MPH are good for 10's.. the car in the street was a monster...
so if you are running 110. look for 124-126 easy ..
I think nickel for nickel NOS is the $hit .
just watch the bottle pressure ..
Old Nov 27, 2007 | 11:54 PM
Slovette2000
Originally Posted by vegasredz062
I can answer that
what kit should I get?
Old Nov 28, 2007 | 12:03 AM
vegasredz062
St. Jude Donor '08
I had the TNT kit 75-150 jets.
I think they were under rating them so a 150 shot was more like 175..
I would go with a wet system NX express is pretty good and reliable company.
zex has some good saftey features..
Old Nov 28, 2007 | 12:41 AM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
10.85@128.9, 1.531 with a dual dry on bonestock LS6.
Robert
Old Nov 28, 2007 | 01:03 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Kit selection is a function of what your looking for. First you have to decide on Dry or Wet. If Wet then you have Nozzle, Plate, Direct Port or the NX MAF kit (They have a NX dry as well now).
Dry, a limiting factor may be the Stock injectors, my 99 I could only spray a 50 shot dry, a 75 shot would go way lean. Other guys with the same injectors were able to get 100-125 out of them (don't know if they were monitoring AFR or not...). Upgraded to 42's and my AFR is spot on, and plenty of room on the duty cycle to go higher.
A little time researching is needed as to your needs. All of the kits will work, when correctly installed. Kit selection can also include how it looks if your interested in showing.
Once you have your kit, you should have a heater or nano as an accessory because nitrous safely works based on safe AFR, so Bottle pressure is very important. Bottle pressure low, you do not get the full shot effect because the car will be rich, bottle pressure to high, and the motor will lean (very bad for the motor).
You will also need ensure you have the fuel pump for it. Stock pump I sprayed to 466 RWHP and had no issues (Stock 300 RWHP N/A). Someone already at 450 or 500 RWHP probably may need a pump.
You will also need to switch to a colder plug TR6's is what most use gapped at .035
A good place to start researching is LS1tech.com Nitrous forum and read through the sticky's.
Last edited by Beer99C5@FastbirdPerf.com; Nov 28, 2007 at 01:42 AM. Reason: Added Dry info
Old Nov 28, 2007 | 01:26 AM
Higgs Boson's Avatar
Higgs Boson
I ran 10.86@129 on a stock motor with longtubes and a DRY 150 shot. With sticky tires you should go a low 11 without issue.
My stock injectors were good to about 475 RWHP. I added some bigger ones for my final numbers of 500/530. Still on the stock pump with no issue. If I do heads/cam I will upgrade the fuel pump.
A 500 RWHP Cobra avg ET would be around 12.teens on street tires and mid-high 11s on stickies. The only reason I don't have one is because they are so heavy. My vette is a second faster with the same HP!
Old Nov 28, 2007 | 01:33 AM
bgreen83's Avatar
bgreen83
sheesh i got about 460 to the wheels now. i guess i have to look at upgrading the fuel pump. I want a 150 shot right now until i get the money to start on a TT setup, love this forum. thanks for the info
Old Nov 28, 2007 | 02:57 AM
skydive120's Avatar
skydive120
Have limited experience with N20 but can tell you I love my ZEX wet kit.
It was very easy to install, works great every time, and has built in saftey features. If the bottle pressure is low it limits the fuel, so no running rich.
Would always reccomend a window switch and bottle heater, a few extras now can save you thousands later.
Computerized nitrous is a wonderfull thing, if its set up properly!
Chris
Old Nov 28, 2007 | 07:19 AM
KamiLos's Avatar
KamiLos
Chris
Old Nov 28, 2007 | 01:27 PM
Chris.Shea's Avatar
Chris.Shea
ran a fastest of 127mph on a 100shot through my nitrous outlet plate kit. that's a 10mph gain over my N/A mph though I have an LS6. you should expect about the same trap with your LS1 and 150shot.
only thing I would do different is run a stand alone with some higher octane. money well invested IMO.
Old Nov 28, 2007 | 03:59 PM
Vega$Vette's Avatar
Vega$Vette
To answer your question. NO a 150 shot will not keep you up with 500/550 rwhp.
Old Nov 28, 2007 | 04:21 PM
Doczo6's Avatar
Doczo6
Yes it will, he is asking about a 500/550 terminator..ie 03'04' cobra. Which are heavy as hell. Ted's car walked modded cobra's and he was spraying equivalent of 120 shot. I new you wouldnt keep it stock long man
Old Nov 28, 2007 | 05:15 PM
Slovette2000
I got big plans for it but for now this will do it cause being slow sucks ......later I will do a Forged bottom end /alky kit /Novi 2000 plus whatever supporting mods I need .....you need to just sell me yours
Old Nov 28, 2007 | 05:29 PM
jogar80's Avatar
jogar80
Chris
That sounds cool, what kit is it, where can I see that?
I'm wondering what happens on a simple wet kit when your bottle pressure is too low. Do you still get SOME performance gain or do you actually end making less power than N/A because your running rich?
To nitrous question ...150 Shot
Old Nov 28, 2007 | 06:32 PM
skydive120's Avatar
skydive120
With the ZEX kit you will still have an increase in performance, just not as much as you would at full pressure- hence the bottle heater to get more consistent performance.
Here is a link to the kit I'm running.
http://www.zex.com/
EFI WET NITROUS SYSTEM - LS1 Engines
Part #82026
Old Nov 28, 2007 | 06:59 PM
Doczo6's Avatar
Doczo6
LOL man i am supposed to get my car back Tues of next week i hope we all need to hang out some
Old Nov 29, 2007 | 03:21 PM
CraZee ZO6's Avatar
CraZee ZO6
must have with nitrous- MSD window switch (On 3k+ off before limiter).
WOT switch (only spraying when WOT if you get out of it its off and get back on it its back on. very good for traction issues), fuel pressure switch (failing fuel pressure, juice off), GOOD bottle heater, nitrous pressure gauge.
