Methanol Injection Pics Wanted
Old Nov 29, 2007 | 12:38 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Methanol Injection Pics Wanted
I was wondering if any of you guys in the forum with an A&A Vortech system have methanol injection. If so, can you post pics of where you mounted your spray nozzles.
Thanks,
John
Levittown, NY
This is the system I'm running that I want to add meth too. It doesn't seem like there is anywhere to mount the nozzle between the MAF and throttle body.
Old Nov 29, 2007 | 12:51 AM
2004SpiralGrey
Also where did you mount your meth controller???
Old Nov 29, 2007 | 05:32 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
It will make sense when you get the kit from Andy, but you drill and tapp the throttle body, and then mount the nozzle there.
Heres a pic of the finished product
The work in Progress
The meth controler comes mounted on the tank which I didnt like because it was very hard to read the controler ***** to make sure I had everything spraying at the desired psi. So I decided to extend the controler harness and mounted it in the center console in the ashtry spot.
I dont have a pic of this yet, but I will take one when I get home today and post it up for you. This was the best change I made to the kit by far!
Andy Wheeler
Old Nov 29, 2007 | 11:12 AM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Another option that doesn't require you to drill and tap the throttle body is to simply insert a 2.5"-3.0" long piece of round piping in between the mass air meter and the throttle body. See the pictures below.
Old Nov 29, 2007 | 12:07 PM
Mike04's Avatar
Mike04
You can see one of my nozzles in the pic. The other is on the opposite side. I have a metal ring inside the coupler to give it a solid mount. I have the controller under the ash tray cover.
This pic is prior to loosing the maf with a SD tune. My nozzles are moved forward now.
Old Nov 29, 2007 | 12:30 PM
2004SpiralGrey
Thanks for all the pics and the good info
To Methanol Injection Pics Wanted
