Quick Question about NOS
Dec 9, 2007 | 01:58 PM
St. Jude Donor '10
Is it ok to mount one or two small nos bottles under tho hood. I want to put them were the windsheld fluid tank goes.Thanks for the help
Dec 9, 2007 | 02:07 PM
No, there is too much heat under the hood for a bottle. The heat would cause an overpressure which could be bad.
Dec 9, 2007 | 03:01 PM
I agree.. bottle pressure would go through the roof... best place in a C5 is in the center rear compartment. Hidden, and not in the path of heat
Dec 10, 2007 | 08:14 AM
Quote:
Originally Posted by
ICULUKN-C5
Dec 11, 2007 | 08:41 AM
St. Jude Donor '08-'09-'10
If bottle pressure were to "go through the roof", wouldn't simply purging the system relieve the pressure??? I am not a NOS expert but it is common sense. I say go for it Shagster, it sounds like a cool idea!!!!!
Dec 11, 2007 | 10:17 AM
You can purge the system via a purge button. If bottle pressure gets too high (around 1600), the pressure may be too much for the solenoid to open.
Also.. There is no real science to the pressure discs for the blow down.... Some will pop at 1600.. some 1800... If you pop a pressure disc then you will lose all your nitrous.
Dec 11, 2007 | 12:27 PM
St. Jude Donor '10
Nos
Thanks for the info guys
Dec 11, 2007 | 12:48 PM
Shagster
Anytime!!!! Just make sure you let us know how it goes when you put the NOS bottles on your car!!!!!!!!!!!!
Jan 3, 2008 | 05:37 PM
Bottle
Yea, let us know when the car, garage and house blow up!! don't listen to us guys with 20 years exp....
