METH before & after timing question???
Old Dec 13, 2007 | 12:27 PM
turboteal's Avatar
turboteal
Default METH before & after timing question???
what was your timing on a supercharged car before meth/alcohol injection and then after ???? how much power did you get
Old Dec 13, 2007 | 12:41 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
To make the responses to this thread more useful, you may want to know how much boost is being run, what heads/cam are on the car (some heads can take more timing it seems), if static compression has been changed, what meth/water mix (if any), and what grade of gasoline the car regularly runs.
My money is on an average of 4-6 degrees of timing and 25-35hp depending on boost, compression, and octane for 100% methanol.
Old Dec 13, 2007 | 12:46 PM
turboteal's Avatar
turboteal
boost levels of about 5 to 9 lbs of boost, 10.5 compresion ratio, stock 2004 ZO6 motor.
Old Dec 13, 2007 | 01:40 PM
clemsondave's Avatar
clemsondave
that's about where I'm at. '03Z; 7# on a P1. Just shy of 600/500.
Old Dec 13, 2007 | 02:00 PM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
It's not about how much total timing you can run. But rather what's the least amount of timing which allows you to make the most amount of horsepower while still being safe. Often times, when working with water methanol injection, we will reach a point where adding additional timing no longer increases horsepower. Yet we are still able to advance timing further without the engine knocking for example.
Old Dec 13, 2007 | 11:43 PM
turboteal's Avatar
turboteal
im wondering if your timing should be around 15 degrees to be safe
Old Dec 14, 2007 | 02:38 PM
redcycle13's Avatar
redcycle13
Not really sure what the timing was prior to meth, but I run 19 degrees. This is on a 347ci 9.0cr motor with 15lbs boost. I tried to run it higher, but it didn't make any really noticeable power gains above this.
To METH before & after timing question???
