Gauge install question
Old Dec 17, 2007 | 09:09 PM
NAPZ06's Avatar
NAPZ06
Default Gauge install question
Anyone know where I can get the plastic plate to install a boost guage in the cigarrette/ashtray opening? Thanks
Old Dec 17, 2007 | 09:12 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Forum member Beer99C5 or forum vendor Cajundude
Old Dec 17, 2007 | 09:13 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Forum member Beer99C5 Just send him a PM
Old Dec 17, 2007 | 09:14 PM
16Again's Avatar
16Again
Beat me to it I need more juice for my finger to keyboard.
Old Dec 17, 2007 | 09:19 PM
FactoryRaceCar
Hey Bob
Merry Christmas
Old Dec 17, 2007 | 09:30 PM
syko Z06's Avatar
syko Z06
I know most of us want a clean looking install but if you are going to use the ash tray for a boost gauge you should use one that records max boost. It would be like changing the radio while racing. Just my opinion. troy
Old Dec 17, 2007 | 10:00 PM
NAPZ06's Avatar
NAPZ06
Thanks alot I appreciate the info.
Old Dec 18, 2007 | 02:56 AM
FactoryRaceCar
Only wideband in the ashtray area for me
Boost and Fuel Pressure gauges are on the pillar along with the Alky and Raptor Shift Light
Old Dec 18, 2007 | 03:49 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
I encountered that issue with my Stage Activation lights in a similiar panel for Nitrous (could not see them without looking down)...moved them to the pillar. Light placement was to mimic the tach needle (stage one low RPM, Stage two high RPM), as well if they were above one another I was concerned that one glow would block out the other and make it indistiguishable.
Old Dec 18, 2007 | 07:17 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You might want to forgo using the B@@ST gauge in the ashtray area just because it is hard to see when you are under B@@ST!
Your eyes have to drop way too low in order to see it safely!
I would recommend a pillar and the Wideband A/F Ratio gauge in the ashtray area! IMHO!
Thanks,Matt
Old Dec 18, 2007 | 12:23 PM
lucky131969's Avatar
lucky131969
So your have to look down at the ashtray to see what boost your're at going through the quarter? I remember when the old musclecars had a tach on the console (useless). I always thought that's what the A pillar pods were for.
Old Dec 18, 2007 | 03:02 PM
FactoryRaceCar
Maybe look at BOTH the pictures in post # 8 again???
Old Dec 18, 2007 | 05:29 PM
NAPZ06's Avatar
NAPZ06
I have air/fuel and fuel pressure on my pillar pod which to me on the quarter are whats important. I'd also like to use the boost guage so that's why I was looking for the ashtray mount. Still haven't been able to contact beer99c5 though. Anyone know of a web address to order?
Old Dec 18, 2007 | 06:15 PM
St. Jude Donor '08
Sorry got behind in PM's I am wrapping up a month in Singapore.
Head home today
PM returned.
Old May 14, 2008 | 07:35 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I am planning on placing TWO gages in my ash tray. One is the Autometer boost gage. The second is the awesome PLX DM-200 ODBII!
http://www.plxdevices.com/products/dm200obd/
I need to find a mounting plate that I can use to mount these gages.
Does anyone know where I can find one? My Procharger will be installed in 10 days, so I am trying to find this soon!
Old May 14, 2008 | 09:23 AM
Brandon619's Avatar
Brandon619
Here is another from Beer99C5
Old Dec 2, 2010 | 09:10 PM
T_Vert's Avatar
T_Vert
do you have to cut up the back of the center console where the screw secures it to the chassis behind the ashtray?? What size gauge is that?
Dave
To Gauge install question
Old Dec 2, 2010 | 09:50 PM
madmatt9471
Dave
Not too much cutting!
I just had to lop off the tray so it looks like a window frame. If you don't cut off enough material it will not slide in because it goes at an angle and it'll run into the bottom -
So it is best to cut it close to the actual face as possible, like only have a 1/4 to 1/8 inch of straight lip behind the face plate.
I hope this helps
Thanks,Matt
Old Dec 2, 2010 | 10:00 PM
FactoryRaceCar
Holy thread revival batman! Memories!
Old Dec 2, 2010 | 10:17 PM
T_Vert's Avatar
T_Vert
Id assume you have to cut out the cigarette lighter as well?
