From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Originally Posted by chriswtx
226/232 .581/.581 114+2 LSA
why?? Because thats almost the exact cam I'm running now... 226/232 .589/.591 116LSA +3
As yours is also very close to my selected Comp Blower Cam, 224/230, xer lobes, 114+2, .581/.592
The smaller cam will probably make more torque down low, but the larger cam will not give up A LOT of low end torque and should outshine the smaller one on the top end!
Because it will have enough duration for the blower the LSA is good and not to much and the lift will be adequet for the cubes you are running!
I have a 224/228 581 589 114 LSA and it is awesome in my 346 cid making 591 RWHP and 496 RWTQ! it breathes great and has a small lope almost not noticable!
226/232 .581/.581 114+2 LSA...Thats what i would go with
I'm running the one below and it is extremely streetable. I could drive in 6th gear cruising at 1100 rpms with zero surge issues. And at WOT it is mean ! ! !
224/230 .581"/.592" 114 lsa
From: Somewhere between mild insanity and complete psychosis
Originally Posted by bowmanized
Supercharged LS2 with S-Trim and LG PROS
215/230 .629/.592 117 LSA
OR
Which one would you pick and why?
Out of those 2, the 2nd.
You have a blower to make your power. Why use a cam with lift over .600? Harsh on springs, possibly having to replace them a couple times over the life of the car, and past the sweet spot of the GM intake anyway.
