getting up to proper bottle pressure
Old Dec 28, 2007 | 04:02 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Default getting up to proper bottle pressure
Before using the nitrous system I understand you should have bottle pressure of between 950 and 1050. I have a bottle heater but it took me 15 minutes to go from 450 to 700. It was still going up little by little but holy moly it takes a looong time.
This seems to be the weakest link in a nitrous system, that is, the time it takes to get to the proper bottle pressure. I want to go fast when I want to go fast and this is not good. Is there a way around this i.e. waiting, waiting, waiting for the bottle pressure to build up.
777
Old Dec 28, 2007 | 08:01 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
The more empty your bottle is the longer it will take to get to the right pressure. Also, you may want to get a bottle blanket as it will help keep the heat from dispersing.
Old Dec 28, 2007 | 09:53 PM
edcmat-l1's Avatar
edcmat-l1
If you're racing, buy a second bottle, and when one gets low swap em out. Depending on the size shot you're running, you may only get a couple passes or 3 before the bottle pressure drops enough to make it much less effective. Combine that with cooler/cold temps and it just doesnt wanna come up to pressure.
Old Dec 28, 2007 | 10:54 PM
skydive120's Avatar
skydive120
Try a second blanket, should help with the recovery time.
Old Dec 29, 2007 | 12:04 AM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Check out the Nano push system. Can be used in place of heater for those that can't wait, lol.
Robert
Old Dec 29, 2007 | 12:34 AM
skydive120's Avatar
skydive120
What is this Nano punch system? Have not heard of it.
Chris
Old Dec 29, 2007 | 01:32 AM
Robert56@RNS
Collections Hold
Chris
Nano is a brand name for a nitrogen push system. Check over at tech in n2o section and do a search for nano, as there was a recent thread on this.
Robert
Old Dec 29, 2007 | 01:33 AM
skydive120's Avatar
skydive120
Will do, thanks for the info!!
Chris
Old Dec 29, 2007 | 05:47 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
The Nitrogen Assisted Nitrous Oxide (NANO) is a bit pricy but does solve the problem of having to wait for bottle pressure
Seems like the best option for consistant times and maximum use of the Nitous in the bottle.
Old Dec 29, 2007 | 09:33 AM
basicstrategy777
Thank you very much for the reply's. They were helpful.
777
To getting up to proper bottle pressure
