Radiator lay down setups...
Old Jan 1, 2008 | 12:44 PM
easyvette's Avatar
easyvette
Default Radiator lay down setups...
I`m currently working on my winter mods. And I am looking to lay the radiator down to go over it with the ducting for air intake. I cant find specific information on how much forward on the bottom I have to move the cradle before I reweld the cradle.. Theres one other catch I`m also installing a larger 2 core radiator be-cool. (I ran in the 230* range on my way home from the Jersey shore last year) I dont know how much that is gonna come into play... Any info would be helpful.
Happy New Year..
Old Jan 1, 2008 | 02:01 PM
RpeterK's Avatar
RpeterK
ecs has a new powdercoated rad support with all the homework done. they will be there tomorrow 609-752-0321
Old Jan 1, 2008 | 02:04 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
Mine is moved back about 3 or 4 inches, along with 3/4" spacers to drop the whole support. Then I had to cut and fold down the lip of the top of the radiator to make room for the 4" pipe going into my F1C.
Old Jan 1, 2008 | 02:53 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
PM sent!
Old Jan 1, 2008 | 04:02 PM
easyvette's Avatar
easyvette
Thanks for the options guys...
Old Jan 1, 2008 | 04:12 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
If the Be Cool is like the DeWitt, it doesn't take up any more space. It is twice as thick, but fills the entire space between the ends, whereas the stock only fills half the space. When I did my Procharger 7 years ago which required the radiator be layed down I had a bracket welded. Since then there are available brackets which I'd recommend.
Old Jan 1, 2008 | 11:43 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by easyvette
I am looking to lay the radiator down to go over it with the ducting for air intake. Any info would be helpful.
Happy New Year..
What if you could go through the radiator? That would...well, be cool!
Old Jan 2, 2008 | 05:04 AM
easyvette's Avatar
easyvette
Wouldn`t help needs to be round and over on the right some thanks....
Old Jan 2, 2008 | 09:49 PM
robert miller's Avatar
robert miller
NOW THAT IS REALLY COOL!!!!!!
Old Jan 3, 2008 | 08:00 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I modified the hole with photoshop but we could put the cutout just about anywhere. You want to go with a rectangle cut because round would eat up too much radiator. We did this a couple times and the guys fabbed up a round-to-rectangle adapter. This may not work with cars with AC because of the condenser in front.
Old Jan 3, 2008 | 08:52 AM
NemesisC5's Avatar
NemesisC5
Definetely a move in the right direction, I was just thinking of a shorter radiator. Are you talking of shaping a dip in the tubes to allow a 4" inlet tube to the supercharger without modifying the radiator location?
Old Jan 3, 2008 | 03:41 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
We already have the adpater tabs which leave a small (7/8" gap) on the top. Then we would just disable about four rows, which would give you 1 1/8 + 7/8 = 2" high So a shute 2 x 6" = 12cu in. is equal to a 4" round pipe (Dia squared x .7854) 4 x 4 x .7854 = 12.5
Old Jan 3, 2008 | 07:46 PM
NemesisC5's Avatar
NemesisC5
Any pictures Tom?...How much does this mod cost if I already have your radiator (no internal cooler)?
Old Jan 3, 2008 | 08:06 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I don't have any photos but just imagine a 2 x 6 rectangluar slot in the upper right hand corner. We wouldn't charge extra for doing it on new radiators but I can't do it to an existing one.
easyvette's Avatar
easyvette
Now I have some real serious interest in your posting Mr.Dewitt Can you get me some pics of this setup....And the price also...Packing the manual trans also no trans cooler needed....
Old Jan 3, 2008 | 09:16 PM
NemesisC5's Avatar
NemesisC5
Why not???
Old Jan 3, 2008 | 09:20 PM
easyvette's Avatar
easyvette
Would this have any signifigant affect on cooling, its ability to cool? Want to make sure this radiator is gonna preform as a dewitt is expected to....
To Radiator lay down setups...
Old Jan 4, 2008 | 07:01 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Why not???
I posted this last night but it never showed up? Must have hit the wrong key....Here is a new concept photo
Why not modifiy an existing one?
Because the two lightlighted rows are welded shut, before the end tank is welded on.
Does it effect the cooling?
Sure, because we eliminated a total of (4) four tubes however the upgrade from stock is still about a 95% improvement over a single row.
All I'm saying is this might be a better solution to laying the radiator down and modifying a whole bunch of stuff.
Old Jan 4, 2008 | 09:38 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Tom, how many inches is removed? I think you may need to take that mount off the whole top of the rad because you also need clearance for the pipe that goes from the intercooler to the TB. I know in Andy's new kits he drops the whole cradle-I think dropping the cradle and making a rad like this would be the ultimate solution. I'm going to pm Andy and ask him if he'll tell us what the size of the spacers he used to drop the rad is.
Old Jan 4, 2008 | 09:47 AM
Smoove
Guest
Posts: n/a
To the original poster...this is what I did after installing various kits on customers cars...
What I did, to my own car was, cut off the bar, that the radiator supports sit on,...cut off the TWO squares that the radiator sits in place as well. Try to keep them together. Then,.."I" moved mine,(the bar and two squares) 6 inches forward. I then re-welded them in place.
Doing this, allowed me to fit large charge and feed pipes up and over my stock radiator.
I had to mildy, and CAREFULLY bend the condensor hard line just a little, to work with the new tilted setup.
It works great,..you can't see where the old brackets lined up and where cut off...etc.
Again, just cutthe square tube/bar off, with the two square mounting tabs that the radiator sits on,...and move them six inches forward... or right near where the bracket starts to curve up.
Hope this is understandable and helpful.
Peace.
Oh yes...your gonna have to make a custom hose setup for the radiator....cause ifyou re use the stock one,..from the NEW rake on the radiator..it'll cause the hose to kink up..
