Spark plug quesstion
Old Jan 6, 2008 | 10:25 AM
philsy's Avatar
philsy
Default Spark plug quesstion
What plug do you use with a supercharger setup?
Old Jan 6, 2008 | 10:38 AM
Mike04's Avatar
Mike04
NGK TR6 with .035 gap
Old Jan 6, 2008 | 10:39 AM
AREC5's Avatar
AREC5
That would do it!
Old Jan 6, 2008 | 10:48 AM
philsy's Avatar
philsy
thank you thats what I have just took the nos off and installed a P1sc yesterday. It came with a Diablo tuner I install the tune and the car is smokeing pretty bad any Ideas ? tips on what to set the timeing ? etc...
car idels really ruff and stalls out in park.
thanks for the help
Old Jan 6, 2008 | 11:01 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Up to 15 the TR6's work great. Easy to find and cheap!
Old Jan 6, 2008 | 11:02 AM
AREC5's Avatar
AREC5
thanks for the help
What colour is the smoke? if its black it would looks like your injector cal is off or your fuel pressure is not stock, address this soon so you don't wash out the rings if infact its running so rich it won't idle. What year is the car? if your intake air temp sensor is faulty or not plugged in it will also do this. good luck.
Old Jan 6, 2008 | 11:11 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Who's P1 kit did you install? Check and make sure that all connections, silicone hoses between the MAF and TB are not loose and letting in unfiltered air.
Old Jan 6, 2008 | 11:13 AM
philsy's Avatar
philsy
black smoke , 2003 stock LS1 where is the intake air temp sensor located ? so I can check it,
thanks
Old Jan 6, 2008 | 11:14 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
On the 03 the IAT sensor is part of the MAF.
Old Jan 6, 2008 | 11:15 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Are you sure the MAF is plugged in?
Old Jan 6, 2008 | 11:28 AM
philsy's Avatar
philsy
its a procharger system , we took it off another vette but it was a 2001 vette i just switched out the mafs with the whole system, but now that I look at it the mafs are diffrent part no#'s could this be my problem ?
Old Jan 6, 2008 | 11:33 AM
AREC5's Avatar
AREC5
The maf could be your problem, it sounds like it might be a truck maf. Do you have your original one to swap out?
Old Jan 6, 2008 | 11:42 AM
philsy's Avatar
philsy
yes doing it as we speak i'll be back in about 10 mins... thank you
Old Jan 6, 2008 | 11:44 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
As long both MAF's where 85mm(Black), it should be okay-but it wouldn't hurt to switch them out.
Old Jan 6, 2008 | 12:03 PM
philsy's Avatar
philsy
switched them out reflaching com. now
Old Jan 6, 2008 | 12:14 PM
philsy's Avatar
philsy
switched them out now the car is running good letting it warm up now than i'll take it for a test drive the smoke is gone now ... it was smokeing at intial start up but it cleared up in a few mins. I need to jocky some cars around to get out of the garage. I'll be back shortly thanks for all the help guys... I will be back lol
Old Jan 6, 2008 | 01:20 PM
philsy's Avatar
philsy
all is well thanks guys no codes thrown this thing is a beast now.... Thanks again for all the help.
Phil
Old Jan 6, 2008 | 01:48 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Phil
Your hooked!!!!!!!
Old Jan 6, 2008 | 06:57 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm using my NGK TR 55's still and no problem!
What is the benefit of the TR 6's oner the 55's?
Thanks,matt
To Spark plug quesstion
