What oil are you using??
Old Jan 10, 2008 | 12:11 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
Default What oil are you using??
What kind of oil do you guys run in your forged engines?? (The engine is an MTi 347, with a D1SC FI)
I'm currently running the 15W40 since I'm still under a 1000 miles on the new motor, but I'm getting close to the first oil change.
What do you guys recommend, I've heard so many things from so many reputable places I don't know what to go with
Synthetic?
15W40
10W30
5W30
Thanks for the advice.
Matt
Old Jan 10, 2008 | 07:11 PM
HRTBRCR's Avatar
HRTBRCR
Default oil
I discussed this with my engine builder....My motor is a forged 402 by canadian Performance. Dave wants me running 20w50 Castrol regular oil...but he wants me changing it every month. We are not really letting the oil break down. I noticed how cold it was getting here in Toronto in November, so I put in 10w30...but once the weather gets nice I will be changin back to the thick stuff. I have thought about the synthetic...but I really like super clean oil in my motor. Its very good for the bearings..and by changing the oil very often, we are keeping all the gas and pollutants out of the oil. Hope this helps you. It sure is nice when I change the oil, and its still brown, not black.
Old Jan 10, 2008 | 09:02 PM
leojnknsC5's Avatar
leojnknsC5
YOu might ask the builder how tight he set up clearances in the motor. A thicker oil is good in a "loose" motor, and a thinner oil is better in a tight motor. If your running 15w40 to break it in and your pressure is fine, no reason to change it. But I'd definitely run a full synthetic like Royal Purple and change oil at 3000 mile intervals instead of 6000+ like RP recommends.
BTW, if you run thick oil, it creates more internal static drag than a thinner oil will. But a thin oil may not give good pressure.
Old Jan 10, 2008 | 11:09 PM
RED99's Avatar
RED99
I was running Mobile 1, but the last change I went with Amsoil. I run OEM recommended weight. I have high oil pressure, and wouldn't want to run anything thicker.
Old Jan 10, 2008 | 11:20 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Synthetic?
15W40
10W30
5W30
Matt
This is right on point for me as my new forged 347 LS6 just got dropped into my 02 blown Z.
If i were you I would change the DINO oil ASAP as most change their oil on a brand new motor within 500 miles. My brand new Erik Koenig 347 Motor just had its first 50 miles put on today and per my engine builder the oil and filter wil be chaned now and then again after another 500 miles.
I have decide to play things safe and run non snthetic oil for the first couple of thousand miles (about 3000) and then will switch to fully synthetic like Mobil One.
Until then it will be a 5/30 or 10/30 (in the summer) Castrol, Valvoline (non synthetic) as I want to minimize any chance of oil consumption.
After next oil change after another 500 miles,will probably change every 1500 miles (2 times) and go to a full synthetic!
Old Jan 11, 2008 | 07:12 PM
leojnknsC5's Avatar
leojnknsC5
Right. You wont get good break-in results with a full synthetic. However, after break in, a synthetic beats a conventional hands down because it handles heat so much better. Thats why the C5's fans come on at 230* in a stock LS1 and it comes with synth.
If you run a conventional oil at engine temps above 212*, it's life is drastically shortened. REmember, if the engine is at 212, the oil temp can be considerably higher.
Old Jan 11, 2008 | 07:56 PM
DALLA1's Avatar
DALLA1
i like hash oil!
Old Jan 11, 2008 | 09:56 PM
396375's Avatar
396375
St. Jude Donor '08-'09
So how does GM break in our motors when they are new with synthetic oil?
Old Jan 12, 2008 | 12:54 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I used dyno oil the first 1,000 miles, changed first time after 30 minutes and then at 300 miles and again at 1k. This in my little ole 346/7 and then onto RP 10/30 and I change at 2k or sooner, why oil changes are cheaper than my engine. What I have found is when in boost I use oil and when I cruise on the hwy no oil use. With 10k on the motor and a oil change last night all seems fine and more boost on the way home last night, yea I live 25 miles away from my wrencher. I can not say the RP is better or worse than any other syn oil, but my mechanic uses it and I follow suit
Old Jan 12, 2008 | 04:42 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
I use Amsoil 10-40 on my 99 FRC.
Old Jan 12, 2008 | 12:37 PM
leojnknsC5's Avatar
leojnknsC5
I was told at the dealership by teh resident service manager who was also the corvette expert that the motors see breakin on a dyno before installed in teh car, with regular oil
Old Jan 12, 2008 | 01:43 PM
ONE BMF's Avatar
ONE BMF
Check this link and make up your own mind-pay close attention to the pressure resistance http://www.animegame.com/cars/Oil%20Tests.pdf
Old Jan 12, 2008 | 03:13 PM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
for my 50k motor I only used the purple stuff, why scimp on the little stuff, doesnt make sense. Go with the best oil to reduce the chances of motor damage
Old Jan 12, 2008 | 11:11 PM
leojnknsC5's Avatar
leojnknsC5
Thats amazing that RP beat Redline hands down. I know what I'm running.
Old Jan 12, 2008 | 11:50 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm running Mobil1 15W 50 in my '98 with 86,000 miles on it with no issues!
Thanks,Matt
Old Jan 15, 2008 | 05:37 PM
396375's Avatar
396375
That's news to me.I've taken the plant tour 6 times.I wonder how they would put any kind of mileage on the dyno?
Old Jan 16, 2008 | 08:47 PM
TLewis4095's Avatar
TLewis4095
We break in all motors we build w/shell rotella for 500 miles & then it's M1 or any good syn EXCEPT RP. RP is the only oil we have seen bearing failures with. RP makes great gear lube & other products but the thin super sheeting film may net a few extra HP, but at the sacrifice of the engine internals (on race motors....may be fine in street motors). We use 10-30 in street built motors where our bearing tolerances are set at 2 1/2 thou....but our race motors are around 3 so we run 15-50 M1 or equivelant.
To What oil are you using??
