Block Choices
Old Jan 13, 2008 | 10:39 PM
Mean Gene55's Avatar
Mean Gene55
St. Jude Donor '08
Default Block Choices
Gang - I'm already looking forward to building another motor for my C5 D/D ( yes, I'm driving my tuner nuts because I haven't even gotten my F1-R'ed 383 back on the road yet!! ) so I'm looking into my options. Looking through the Scoggin-Dickey website I see a HUGE ( $2500+ ) difference between the cast iron LSx block vs an aluminum Warhawk block. Obviously the aluminum block will be roughly half the weight of the cast iron one but won't the extra rigidity of the C/I block ( thus allowing more boost & the resulting additional power ) offset the extra weight or am I missing something? Both blocks have the 6 bolt head provisions so I don't see a problem w/head lift with either setup. Also, both can be stroked out to the mid 400 cid displacement range. I plan on putting the F1-R on the new motor & also the small ( 50 hp ) nitrous shot that I have on my current engine, BTW.
I'm just having trouble justifying the extra $2500 to save 150# or so in a daily driver. Now if there are MORE benefits that I've overlooked then please help me see it!! Thanks, guys!!
Gene
Old Jan 14, 2008 | 06:59 PM
RED99's Avatar
RED99
For your purpose, I would go with the LSX iron block.
Old Jan 14, 2008 | 07:05 PM
Mean Gene55
St. Jude Donor '08
Default Thanks!!
Thanks, Red!! I was kinda leaning that way since I won't ever autocross the car & even if I do I have a set of Pfadt coilovers I'm waiting to install so I could probably adjust those to compensate for the extra nose weight.
Gene
Last edited by Mean Gene55; Jan 14, 2008 at 07:07 PM. Reason: Punctuation correction
Old Jan 14, 2008 | 10:06 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Gene
LSx Iron block is only about 100 lbs more and since the motor is set back it's not that much of a difference.
The placement of the blower causes more weight over the nose than the heavier block.
Old Jan 14, 2008 | 10:18 PM
mdhmi's Avatar
mdhmi
I'm not sure I'd be using the words "only" and "one hundred pounds" in the same sentence.. We're talking about Corvettes here, not Camaro drag cars.
Old Jan 14, 2008 | 10:25 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Well if you're like me and switched from an auto to six-speed you would be able to take the 100 lbs no problem.
Heck with all of the missing body panels on my car, I bet I got one of the lightest vettes around.
Old Jan 15, 2008 | 11:15 AM
Mean Gene55
St. Jude Donor '08
Default Plans??
Widebody in progress??
Man, I wish we'd met earlier because I'm contemplating a switch to an
A4 from my M6. :o
Gene
Old Jan 15, 2008 | 11:23 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I got you dawg... what do I win?
Old Jan 15, 2008 | 12:08 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
A4 from my M6. :o
Gene
Yeah, I'm still working on my wide project w/ Kerry the owner of ACP. He's a great guy, I've probably driven him over the last couple of years.
Should be headed back to ACP later this week to drop off the car and aboat load of parts to complete the conversion from Coupe to FRC and then the wide body work.
You win a date with the paint shop. BTW, where is that sample paint panel you promised ?
Old Jan 15, 2008 | 12:56 PM
Cobra4B's Avatar
Cobra4B
^ They are doing it today... didn't get to it yesterday.
Old Jan 15, 2008 | 06:06 PM
396375's Avatar
396375
St. Jude Donor '08-'09
The 100#s will cost you 1/10 in the 1/4 or 1 car length on the street.If you run a FI setup and blow a head gasket you may torch the block if it is aluminum.If the block is steel you are more likely to torch the heads if they are aluminum which is a much easier fix then pulling the block.
Take care.
To Block Choices
