Blowing out dipstick
Obviously I want to prevent this from happening again in the future. What tricks to you guys use to keep the dipstick in under high boost? My shop told me they have heard of guys rigging up a spring to hold it down?? Any pics of this? Other tricks? Would a valve cover breather do it?
By the way, where in the heck are you driving your car around here, the roads have been crappy for days?
Ya, roads suck. I had no business being out, but I had to take it out to bowling night to show the guys. It was a tractionless show of engine revving noise pretty much. Is it May yet?
The PCV system is stock, so it looks like I'm going to have to order some aftermarket stuff. A catch can with larger tubing and those KankVents look like they should do the trick.
Suggest you might want to call ECS, EPP or Andy at A&A for a second opinion. Something sounds off.
Good luck. Hope it's nothing difficult to fix.
I already had a catch can and took the pcv hoses off and plugged the openings that run along the rear of the motor and also installed the LS6/Z06 valley cover with the nipple on it to hook up the catch can and also put a vent where the oil cap goes. That worked for me.
Putting a spring on the dip stick is kind of like putting a cut off finger back on with duct tape. It solves the situation, but not the root of the problem. I vote for the pcv system being the problem! Good Luck!
I also agree with Snitz. I'd also leak down the motor just to be sure that something didn't happen. Just my .02
An engine leak down as suggested above is a good idea along with a breather/catch can system along with disabling the PCV system so boost doesn't go into the crank case.
Another point to consider is that detonation at WOT will also create excessive crank case pressures. You may also have one or more of the following: Too much timing, too much compression, low fuel octane, elevated inlet air or coolant temps, bad fuel pump, clogged fuel filter or the fuel system may be inadequate for the power, not enough injector (check DC), wrong spark plug heat range, tuning.
Julio
Here is what I did with my set-up:
http://www.racetronix.com/product/RX-CEPH/RX-CEPH.html
This Racetronix harness utalizes the SMOG AIR PUMP as an evac pump!
Most of us have ours already turned off and it is just sitting there! It is an easy hookup and install.
More than likely your AIR PUMP has been turned off by your tuner (Or yourself) and can be utalized to evac pressure under B@@ST!
Take a look and see for yourself! It is at least going to help to a degree!
If you use a "BREATHER" then you will only make the Crank Case the same as the atmosphere and it's pressure. WHY?
Because what happens is an equalizing in pressure your evac system will pull from the breather (Which is open air INLET to the closed Crank Case) and minimaly from the crankcase! That is why so many have the mess from the breathers becasue it still pushes the pressure out from the crank case ( The dreaded "OIL MIST") and all over the motor.
But if you have a evac system you want to keep it as a closed circuit - either your evac system will be from the valve covers into the AIR INLET on the SuperCharger or from an evac pump it will need to be closed to be effective!
DO YOU HAVE A ONE_WAY CHECK VALVE? http://cgi.ebay.com/ebaymotors/NEW-3...2em118Q2el1247
Just put two fittings on it and intersect the line from the TB or Manifold
so when it goes under B@@ST it closes and does not pressurize the crankcase! many over look this and blow out the dipstick or worse!
Most come off the manifold right behind the TB then to the Valley Plenum Cover or to a Valve Cover and don't use a check valve to close when it goes under B@@ST and actually B@@ST the crankcase!
I can give you more info on this set-up so you don't pressurize or B@@ST the crankcase!
Thanks,Matt
Thanks,Matt
The OEM electric air pumps will fail in a short period since they were not designed to pump hot air containing oil and exhaust (blow by) for extended use and also may not be able to keep up with the amount of blow by depending on power level and engine build. With a check valve preventing boost from flowing to the crank case you will probably end up with oil in the intake, not good for a boosted engine or even an NA engine. So considering what I just mentioned, I opt for a well implemented breather system in a high HP C5 and a purpose built evacuation system in a race only vehicle and a PCV system on a bone stock engine.
Julio
Matt, I respectfully disagree, here is why. While the idea of evacuating the crank case is great and will help make more power, you really need a purpose built (Moroso and alike) belt driven vacuum pump system with breathers, liquid to air separator and regulator that would be very difficult to install in a supercharged C5 with all accessories. These systems are often found on race only vehicles since they aren't designed for daily driving.
Julio
I just want to clarify that this is not the only source of EVAC that is being used it is juat a secondary "PRECAUTION" or help for the blower motor application.
I have mine plumbed into the opposite side valve cover and into the air intake of between the blower and airfilter so while under B@@ST it sucks from the power of the blower! and the opposite side closes under B@@ST otherwise one would B@@ST the crankcase
The "RACETRONIX" wire harness does "NOT" run all the time as you made it seem!
If you look closely it has a B@@ST operated HOBBS switch that comes on under 4 PSI of B@@ST so it does "NOT" run continuously - which it is not inteneded to do even under factory settings (Has a run time of 30 seconds on start up) as we do not run around under B@@ST continuously!
OIL will "NOT" be running through! WHY? because there will be an inline catch can!
AGAIN it is only a means for secondary evac of the crankcase pressure.
One can do whatever they want on their application this was just a mere extra that I've been using recently -
All this is only IMHO!
Thanks,Matt
I do this on all my supercharger installs.
I also take a pair of wire cutters and put a very slight crimp in the top of the tube, above the o ring. That really helps to hold the stick down. Some of them are very loose.
This is the way to fix it if there is not an engine problem. It is not intended to cover up blowby due to a burnt piston etc.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
