Electric Vacuum Pump from SSBC
Old Feb 3, 2008 | 03:24 PM
NemesisC5's Avatar
NemesisC5
Default Electric Vacuum Pump from SSBC
Could this unit by itself or being Overspun by BAP or other voltage multiplier pull enough vacuum through a Filtered Catch Can System to keep our intakes cleaner & in addition help to seal piston rings??? I would rather not install belt driven unit but like the benefits of a vacuum pump ...Just an idea, "Flame Suit On"
http://www.ssbrakes.com/pdf/AC001.pdf
Old Feb 3, 2008 | 04:19 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Not holding my breath on that one.
Old Feb 3, 2008 | 04:27 PM
Skunkworks's Avatar
Skunkworks
Save your money as it will have nowhere the CFM to do an adequate job.
Mike
Old Feb 3, 2008 | 05:04 PM
NemesisC5's Avatar
NemesisC5
Mike
Thanks Mike...What is CFM rating for belt driven Moroso, etc., units?
To Electric Vacuum Pump from SSBC
