STS TT Question
Old Feb 8, 2008 | 01:12 PM
MagRedConv's Avatar
MagRedConv
Default STS TT Question
Good afternoon,
I have a '98 A4 conv. stock with the exception of a Corsa X-pipe and Pace Car exhaust. I own the car and was thinking of getting an '08 when it dawned upon me - $40k for 80 hp? That is what brings me here.
I've got 79.7k on the odometer and it's a daily driver, I'll be keeping it for a few years easy. I've looked at SC and Turbo and have decided on Turbo as the avenue I'm going to travel. BTW, I live in Austin TX and have a facility that's installed many a STS unit on a C5, so I'm comfortable with that aspect (if there's anyone out there from ATX with the STS installed please pm me).
So my question is this:
Has anyone with this kit installed noticed or experienced anything out of the norm (temp, oil consumption, drivetrain issues, etc.)? If you had it all to do over again would you hesitate?
Thanks much,
Bill
Old Feb 8, 2008 | 09:08 PM
thetoy's Avatar
thetoy
I have a 99 corvette that I just picked up today after a sts twin turbo install. It has 100,000 miles on it and its raining here right now so I can't drive it . So i don't know if there are going to be any issues yet but it ran great on the dyno.
Old Feb 8, 2008 | 10:15 PM
bustin knuckles's Avatar
bustin knuckles
From: Sounds like a T Rex lives under my hood. Gibsonton, Fl
Old Feb 8, 2008 | 10:31 PM
MagRedConv's Avatar
MagRedConv
Wow, how's that for timing! I'd really like to hear your impressions on the car once you've had the opportunity to run in dry weather.
Out of curiousity, outside of the STS install, were there any other mods that needed to be done or was it a straight bolt up the kit and let 'er rip?
I almost forgot; what were your numbers?
Thanks again.
Old Feb 8, 2008 | 10:37 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Thanks again.
With an a4 you really need to plan on the turbo kit AND ~$2,000 for a built transmission. I had the procharger installed first - stock 2.73 gears, stock cam, stock torque converter, big transmission cooler, stock runflat tires, all street and no track, babied it. Transmission lasted 2 months.
Old Feb 9, 2008 | 02:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your drive train ain't going to last long.
Old Feb 9, 2008 | 09:43 AM
MagRedConv's Avatar
MagRedConv
You have confirmed my thoughts and I appreciate the imput; and so the shopping list gets longer.
Old Feb 9, 2008 | 10:28 PM
thetoy's Avatar
thetoy
Thanks again.
I had a meth kit installed and had it dyno tuned for a very safe tune the car has 101,000 miles on it. I have only had a chance to drive it around the block so far but all I can say is wow! Here's on off the pulls that were made. Were running just under 8 pounds of boost.
http://video.google.com/videoplay?do...262&pr=goog-sl
Old Feb 9, 2008 | 11:31 PM
MagRedConv's Avatar
MagRedConv
Very cool; you're going to have a blast.
Old Feb 10, 2008 | 12:03 AM
MagRedConv's Avatar
MagRedConv
What are you using?
Old Feb 10, 2008 | 12:08 AM
MagRedConv's Avatar
MagRedConv
Actually, I just noticed you're still looking for a car. What's your experience with the STS system on a C5?
Old Feb 10, 2008 | 10:48 AM
MagRedConv's Avatar
MagRedConv
So what system (TT) do you recommend?
Old Feb 10, 2008 | 12:59 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
There are a ton of people who have installed the STS system. They range from folks who put them on totally stock machines to cars that have run deep into the 9s. It has advantages and disadvantages just like every other FI system out there. My advice is to spend some time digging in the archives, as every question has been gone over a zillion times. Be aware that there are a bunch of STS haters out there, for various reasons. A few of them have even been STS owners. Take posts and opinions, including mine, with some salt. Theory is fine, but look at real world results.
Old Feb 10, 2008 | 01:06 PM
MagRedConv's Avatar
MagRedConv
Agreed. I'm in the "discovery" stage at this point and as you suggested have a plan to explore via different avenues.
Thanks for the straight shooting.
Old Feb 10, 2008 | 01:11 PM
427fIc5z06's Avatar
427fIc5z06
Good afternoon,
I have a '98 A4 conv. stock with the exception of a Corsa X-pipe and ...
Thanks much,
Bill
I strongly suggest reading this thread from a reputable former dealer...
Good luck!
http://forums.corvetteforum.com/show...&highlight=STS
Old Feb 10, 2008 | 01:19 PM
_Will_'s Avatar
_Will_
Great, another high and mighty expert.
Any energy losses or inefficiencies from a rear mount are well beyond the point where a c5 will be able to perform anyway. 9 seconds is just about the limit for a c5. You can count on one hand the number of people with streetable 8 or less second c5s. And by the way, one of the fastest cars on this board that runs lower than 9s has a rear mount setup.
If you are looking to run 9s or slower, the sts kit has been proven to deliver.
For flat out performance the TTiX is better, but some people prefer the sts for other reasons.
The oiling issues were addressed by member here long ago.
Turbo seals has to do with what turbos you get, not the design of rear mount systems.
There are many reliable sts c5s out there on the road. I don't know what you mean about "disproving" the kit. Disprove what? It's a kit designed for c5 owners, intended to be able to deliver certain power levels and certain track times. It delivers both.
Every other kit, turbo or sc, has also had its share of problems.
Last edited by 1%r; Feb 11, 2008 at 10:04 PM. Reason: quote removal failure to move topic forward
Old Feb 10, 2008 | 02:10 PM
FRCTony's Avatar
FRCTony
It still amazes me that there are people who don't believe that rear mounts work...
To those people I say: Seeing is believing.
I would like to see the turbo oiling separated from the engine, and some work to the exhaust for improved sound in normal driving.
I would also like to see a budget rear single for the C5. Something like 5-6psi out of the box with no intercooler.
I think the STS kit could take over the market if they priced it at 5K. Budget kit could be 3.5k.
STS is also one of the few CARB approved FI kits out there.
To STS TT Question
Old Feb 10, 2008 | 02:43 PM
MagRedConv's Avatar
MagRedConv
I thank you both will82 & FRCTony for the straight shooting as well.
Old Feb 10, 2008 | 02:56 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
So you look at pics of the TTIx kit and fap it too huh?
You know nothing about what you are talking about, I'm an engineer and an STS owner, Ive done the research, it may not be optimum, but no kit that has come out has been, its all trying to bolt turbo's on a car that wasn't designed for turbos, just because they go about it a different way you claim its wrong.
Get off my forum, now. You aren't wanted.
Last edited by 1%r; Feb 11, 2008 at 10:05 PM. Reason: quote removal failure to move topic forward
Old Feb 10, 2008 | 05:11 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Lot's of rear mounts out there that work great. Each system has it's pluses and minuses, it's what works best for your application.
