methanol kit
Old Feb 15, 2008 | 07:13 AM
zo6fever's Avatar
zo6fever
Default methanol kit
can the tank mount under the hood? If so does anyone have pictures
can I use my windshield washer reservoir as a tank?
Old Feb 15, 2008 | 07:52 AM
Mike04's Avatar
Mike04
A very large percentage of people on this forum run the ECS (Alky Control) kit. It uses the windshield washer tank to hold the meth. It works very well.
Old Feb 15, 2008 | 08:43 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Feb 15, 2008 | 08:47 AM
robert miller's Avatar
robert miller
THAT IS WHAT 99% OF THE GUYS DO. SEEN A FEW HAVE MADE UP NICE FAB ONE,S OUT OF SHEET METAL. BUT IN THE SAME PLACE.
Old Feb 15, 2008 | 08:57 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Like others already said, most of our installs use the washer tank, keep in mind though if your going to fab up a tank it needs to be made from stainless steel.
Old Feb 15, 2008 | 09:48 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I have the ALKY Control kit from ALKY Control and it uses the windshield washer tank and it works awesome!
Check this out:a how to
http://www.cajundude.com/ecsalky.htm
Thanks,Matt
Old Feb 15, 2008 | 10:56 AM
waddisme's Avatar
waddisme
I have the AIS kit using the ww tank.
Old Feb 15, 2008 | 02:14 PM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Be sure to check out our all in one rear trunk mount water emthanol injection system. This eliminates the the need of using your existing windshield wiper fluid and losing your windshield washer fluid feature as you do not want to spray straight methanol on your windshield and paint.
Here at AlcohlInjectionSystems.com we take and eliminate the confusion and headaches commonly associated with methanol injection systems, providing convenient and easy to install and adjust systems.
Unlike the competitors water injection kits. Who provide you a box containing bags and bags of parts that must be first assembled together before installing, which can then take between 5-6 hours to complete. Our trunk mount methanol injection system comes pre-assembled, pre-wired, hand tested & ready to install right out of the box. Best of all, our water methanol injection systems can be installed in about an hour saving you time and money.
  • Most advanced and versatile progressive controller on the market - compare for yourself vs. the competitors
  • Each system is pre-assembled saving you time and headaches
  • Each system is pre-wired by us saving you from making a mistake and damaging the system
  • Each system is hand tested before it’s packaged to ensure it’s functioning properly
  • System can be install in as little as 2 hours vs. the competitors kits which require 4-6 hours
  • Quick, convenient installation unlike the competitors un-assembled kits
This is a picture of it mounted in the rear center storage compartment on a C5
Old Feb 15, 2008 | 08:52 PM
Dave concrete's Avatar
Dave concrete
http://s195.photobucket.com/albums/z258/daveconcrete/?a ction=view&current=FASTCAR3-1.jpg The washer tank is best for looks and when you need more meth the DIC tells you.
Old Feb 15, 2008 | 09:32 PM
NemesisC5's Avatar
NemesisC5
I have been considering relocating my battery to the rear passenger side compartment (side benefit will help traction, anybody spraying meth has traction issues ) & installing plastic meth reservoir in front battery area. Below is a link to some plastic 2.5 gallon tanks along with a low level sensor that could be installed. Has anybody has done this???...Any opinions on the downside of installing in this arrangement???
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old Feb 15, 2008 | 10:37 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I've been running Julio's kit for a few years now. It is a very proven setup!
JB
Old Feb 16, 2008 | 04:47 AM
zo6fever's Avatar
zo6fever
thanks for all the info guys and the pictures with details to show how to. The only reason I think I'm going to go with using the windsheild water reservoir is I have a boom box in the hole of the trunk and wouldn't feel safe to have a meth kit just behind my seat.
Old Feb 17, 2008 | 01:41 PM
hak's Avatar
hak
Has anyone installed the AIS system into the rear center storage compartment of a C5. Is it a direct fit or are do you need to modify? Are you satisfied with the performance and reliability.
Old Feb 17, 2008 | 10:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
To methanol kit
