Quick Question about Meth and AIT Sensor
Old Feb 18, 2008 | 11:27 AM
MotleyDrew's Avatar
MotleyDrew
Default Quick Question about Meth and AIT Sensor
Hey guys
Just a thought...... Where is the AIT sensor located on a 2001 Z06. I know the wiring for it is connected to the MAF but where exactly is the sensor. Wondering mainly because i am spraying the methanol from a tapped in hole in my Throttle body and am wondering if it will be reading the AIT's correctly.
thanks lads
Old Feb 18, 2008 | 12:55 PM
Brandon619's Avatar
Brandon619
I think the IAT is in the MAF sensor. I'm running a SDtune but when I first installed my meth kit I took the brown and blue wires and ran it to my new IAT sensor. I bought my Procharger kit used so it had a IAT sensor in the intake plumbing. I hope this helps .
Old Feb 18, 2008 | 01:54 PM
MotleyDrew's Avatar
MotleyDrew
thanks Brandon....anyone else no fore sure? I may as well just call Andy eh
Old Feb 18, 2008 | 02:07 PM
Skunkworks's Avatar
Skunkworks
Your IAT is integral to your MAF as mentioned before... Also I would think you want nozzle(s) further upstream to get a better mix with charge air. Anyway just thinking out loud.
Mike
Old Feb 18, 2008 | 02:17 PM
MotleyDrew's Avatar
MotleyDrew
Mike
thanks Mike ! I guess then my data logging will not be logging the correct AIT if this is the case !
Old Feb 18, 2008 | 02:24 PM
Skunkworks's Avatar
Skunkworks
Yes if I read your post correctly... also mixing of spray (water/alky) is important because you want it mixed and undergoing phase change uniformly.
Mike
Old Feb 18, 2008 | 03:11 PM
MotleyDrew's Avatar
MotleyDrew
I was under the impression I should run staright methanol
Old Feb 18, 2008 | 03:36 PM
Skunkworks's Avatar
Skunkworks
I said water/alky generically...
Mike
Old Feb 18, 2008 | 03:42 PM
Brandon619's Avatar
Brandon619
Skunkwork are you saying it is better to run a mix of meth/water vs. just meth?
Old Feb 18, 2008 | 04:54 PM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Hey guys
thanks lads
1997-2001 IAT sensor is seperate from the MAF
2002-And Up IAT sensor is in the MAF
To confirm this, MAF sensors with 5 wires have the IAT incorporated into the MAF.
Old Feb 18, 2008 | 05:31 PM
MotleyDrew's Avatar
MotleyDrew
thanks !
I guess maybe the 2001 Z06 is the odd ball because my 2001 Z06 has the 5 wire MAF.
Old Feb 18, 2008 | 05:32 PM
MotleyDrew's Avatar
MotleyDrew
Mike
ahhh...gotcha
Old Feb 18, 2008 | 08:20 PM
Brandon619's Avatar
Brandon619
thanks !
I have an 01 and the IAT is in the MAF .
Old Feb 19, 2008 | 06:11 PM
MotleyDrew's Avatar
MotleyDrew
Where is everyone mounting there air intake sensors? I just ordered an older style 2000 one with the gromet and am wondering exactly where you guys are tying them into the intake. I will just take the 2 wires from my maf and route them to the new sensor.
let me know !!
Old Feb 19, 2008 | 07:57 PM
Brandon619's Avatar
Brandon619
Look at my avatar you can see mine on the last black tube before the TB.
Old Feb 20, 2008 | 08:50 PM
MotleyDrew's Avatar
MotleyDrew
Cool...I see yours ! Mine is tapped into the throttle body and I kinda wanna keep it there so does anyone actually have there tapped into the intake?
Another thing Brandon...which two wire is it? colors?
thanks bud !
Old Feb 20, 2008 | 09:57 PM
Brandon619's Avatar
Brandon619
Cool Drew they are the purple and light brown tan colored wires. Also it does not matter the way you hook it up to the IAT sensor
To Quick Question about Meth and AIT Sensor
Old Feb 20, 2008 | 10:09 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Drew-you need to do this:
I make up a new inlet pipe and weld in a actual fitting instead of using the rubber gromet that comes with a IAT relocation kit. The sensor is from a GMC Syclone. I also upgrade all the hose to 4 ply silicone and the 90 degree silicone elbow actually has a steel 90 inside it. The MAF is relocated right after the Intercooler using a 4" 4ply "hump hose"-I also use a screened MAF for more accurate readings.
Old Feb 20, 2008 | 10:33 PM
MotleyDrew's Avatar
MotleyDrew
Well arn't you fancy Can you make me one of these? How much? I am getting anxious to come down for my tune I have a truck and trailer lined up and ready for the nice weather! I guess my only question would be ....how do I fill the whole in my Throttle Body now? I guess I would need to have is welded shut with some aluminum eh ?
MotleyDrew's Avatar
MotleyDrew
thanks Brandon !
