Max PSI?
Old Feb 19, 2008 | 01:39 AM
C5Natie's Avatar
C5Natie
Default Max PSI?
Whats the max psi one can run on an '02 stock LS1 with 1 3/4in long tube headers, offroad xpipe, without affecting long term driveability or reliability?
Old Feb 19, 2008 | 01:44 AM
Skunkworks's Avatar
Skunkworks
http://forums.corvetteforum.com/show....php?t=1926231
Old Feb 19, 2008 | 06:18 AM
trussme's Avatar
trussme
Only As a guide...when ATI/ProCharger sells their P1SC kit for a Stock 2002 LS1 engine (as you have) they will only warrant it when set to no more than 7 psi of boost.
Now, many have found that with smaller pulleys, larger capacity injectors (42# or 60#) and a Great tune, you can go to 10psi on a Stock 2002 LS1, but that is border-line safe on your engine. Carelessness, or mistakes at WOT could be all it would take, and clutch life may be shortened. It all depends on how you drive it..
Old Feb 19, 2008 | 09:27 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I would not go above 10 PSI of B@@ST on a stocker so you can maintain total reliability!
But it would be highly recommended to run some Methanol for the safety factor
Thanks,Matt
Old Feb 19, 2008 | 02:39 PM
C5Natie's Avatar
C5Natie
So, 7-9psi should be on safe side even without meth or alcohol injection?
Old Feb 20, 2008 | 02:29 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
As long as it's tuned properly and not tuned on the ragged edge. You tune it in cold weather and go out in the summer and hammer it, you might find out it had too much timing as well as how much a replacement forged bottom end costs! It's all in the setup and tune. Your vehicle will only be as strong as the weakest link.
Old Feb 20, 2008 | 04:48 PM
C5Natie's Avatar
C5Natie
Thnx guys, good advice.
To Max PSI?
