I was running a complete stock motor with Kooks header and three inch cat back. I loved it ! I picked up a sweet deal on some 60lb Motron injectors with a LS2 Intake, throttle body, and rails. One thing leads to another, we just bolted on some ARP head studs 226/222 cam shaft and cometic gaskets to go with my new NOVI
It is almost time to tune my new found cash cow. I think the clutch will be first to go. My question to you is; what next ?
First the clutch, then the rear. Get yourself a DTE brace and some hardend axles. The tranny's mainshaft won't last long if you launch it or put on drag radials.
You hook and they'll be pieces of your drive train every where ?
There are an awful lot of guys running high hp on a stock mainshaft tranny.
Now that that's out of the way ... Next up is a forged bottom end .. provided a check book racer who can't even drive his FI car convinces you to get a meth kit.
Yes, there are a lot of guys running stock mainshafts, right up until they put on some sticky tires.
Plenty of guys running stock mainshafts, and drag radials with 50+ passes at the strip. I posted last month inquiring about stock mainshaft v/s a 9310. Quite interesting. Some guys have broken the 9310, and replaced with a stock mainshaft tranny, and never had a problem.
I find that hard to belive since the 9310 mainshaft is much stronger than the stock unit.
There are always exceptions to the rule, but there are a lot of other guys out there that broke the mainshafts or differential on a little more than stock power.
A lot has to do with how you launch the car. If you go easy, the likelyhood of failure is lower than the a 5K launch.
I spoke with a drive shaft expert today who explains that 9310 is a common gear material. It is very hard, so hard in fact it is brittle. He does not believe I should install that in a rear mounted trans. He said the stress from the pinion gear will put flex and torque the shaft which will likely snap it.
I never said it could not be done, it's more how you drive the car then anything. I wanted a little extra insurance, plus I like throw my money away.
There must be a reason that RPM and some of the other tranny service shops use the 9310 mainshaft ?
All metal that is stronger has more of a carbon base that makes it more brittle but that does not mean it will break easier.
Softer metal twists and harder metals snap when they exceed their limits. I'm not sure what the limit is on the 9310 mainshafts but I am sure that it is much more than that of the stocker.
Maybe, RPM will jump in and explain the reasoning for the upgraded shafts.
The torque put on the out put shaft during a hard launch or wheel hop will snap the brittle material. It would seem the stock shaft may have a little more flex. I believe some folks are lucky and some have the curse.
