STS Question?
Old Mar 5, 2008 | 05:28 AM
TSL812's Avatar
TSL812
Default STS Question?
I was looking at pics of a STS kit and noticed the only use one 38mm wastegate. It is mounted just before one of the turbos. I was just curious if that would cause the boost to creep? Seems like it would only slow down that one turbo and the would keep building boost.
Old Mar 5, 2008 | 08:45 AM
FRCTony's Avatar
FRCTony
I believe a second wastegate is optional.
Old Mar 5, 2008 | 08:55 AM
robert miller's Avatar
robert miller
2ND IS OPTIONAL. GET IT AND ALSO UOGRADE THE TURBO,S ALSO IF YOU ARE GOING TO BUY.
Old Mar 5, 2008 | 09:13 PM
2000BC's Avatar
2000BC
I got the second. No creep.
Old Mar 6, 2008 | 01:22 AM
stroked408's Avatar
stroked408
What is the pros and cons of running 1 wastegate vs two, Ive also wondered this as I have an sts kit w/ upgraded turbos also. My kit came w/ 1 so what is the advantage of the second?
Old Mar 6, 2008 | 04:56 AM
TSL812's Avatar
TSL812
To regulate boost and eliminate boost creep if needed. Basically a wastegate just blleds off exhaust before the turbo to keep the turbo from building any more boost. If the one 38m wastegate can't bleed of enough exhast the boost will creep up past where you have it set at. If that happens a second one can be added to help bleed off more. I figured a single 38mm would be to small, thats why I posted to see if anyone had any problems.
Have you ever noticed any creep w/ your setup? How much boost are you running?
Old Mar 6, 2008 | 06:17 PM
leojnknsC5's Avatar
leojnknsC5
If you have an xpipe or hpipe, its sealed so when a single wastegate opens, the whole system loses pressure. Two are redundant, just faster because of twice the opening area.
Old Mar 8, 2008 | 04:44 AM
stroked408's Avatar
stroked408
I havent noticed any boost creep w/ my set up @ 9psi. I believe that a single wastegate is sufficient unless you have big cubes w/ high boost and then a second may be required to control creep as there would be more exhaust to bleed off. Someone correct me if Im wrong
Old Mar 9, 2008 | 12:00 AM
TSL812's Avatar
TSL812
Thanks for your repllies! Do you have any pics of your setup? Did you install it your self?
To STS Question?
