BAP install location?
Old Mar 8, 2008 | 09:25 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Default BAP install location?
Some say near the fuel tank and others say near the fuse box. Which one is correct?
Old Mar 8, 2008 | 09:37 PM
AMRAAM's Avatar
AMRAAM
I used the racetronix harness with my install and they had it mounted in the back. I don't think it matters too much as long as the all your cables reach. It is recommended not to shorten or lengthen the pressure switch lines and the controller lines
Old Mar 8, 2008 | 09:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
KB's are set-up to be mounted by the fuel tank and the MAGANAVOLT is set up to be installed by the fuse box!
I have the MAGANAVOLT in the battery compartment by the fuse box neatly tucked in there and covered with the battery den cover!
Thanks,Matt
Old Mar 8, 2008 | 10:17 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Sorry, not true.
The KB is setup to be mounted by the Fuse box if you are not using a Racetronix Harness and in the back if you are.
You can mount it anywhere you want, but these are two locations, I would HIGHLY recommend using a Racetronix harness with it, the wiring setup will be far superior and it makes the installation a breeze.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Mar 8, 2008 | 10:23 PM
madmatt9471
Originally Posted by BLOWNZO6
Sorry, not true.
My BAD then!
It depends on the harness you buy for the KB!
Most install it by the tank!
Thanks,Matt
Old Mar 8, 2008 | 11:14 PM
FRCTony's Avatar
FRCTony
Sorry, not true.
Racetronix harness is money well spent!
You ever going to get that thing running?
Old Mar 9, 2008 | 12:44 AM
Z06PSI's Avatar
Z06PSI
Thats ****ed up. LOL
Business trip to Hawaii and doing this all myself and you want results already? I have done a lot of other things that took up time like tail lights painted, Carbon Fiber vents for the rears, coil pack relocation, etc., etc. Should be done this week though.
P.S. I have the Racetronix harness already and after some research and planning it is going by the pump. Thanks guys.
Old Mar 9, 2008 | 10:30 AM
Lynch Z06's Avatar
Lynch Z06
Mine is mounted by the battery/fuse box
Old Mar 9, 2008 | 03:21 PM
396375's Avatar
396375
St. Jude Donor '08-'09
I mounted mine in the middle of my hood just to give the car that racey look
Old Mar 9, 2008 | 05:03 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Old Mar 9, 2008 | 07:10 PM
philsy's Avatar
philsy
To BAP install location?
