Traps speed question
Old Mar 11, 2008 | 09:18 PM
whitebullet7's Avatar
whitebullet7
Default Traps speed question
i took my car to the drag trip on sunday.i did 12.00 2.2 60'' 125mph
the car make 614/520.i thought it will traps around 130-134 mph.what do you think of it?why the car traps speed so low?is it because of the driver?
thanks
Old Mar 11, 2008 | 09:59 PM
mdhmi's Avatar
mdhmi
Probably a combination of driver, track, weather (DA), and tires..
Old Mar 11, 2008 | 10:33 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It depends on why your 60' is bad too. If you were lazy on the launch to save your car from breaking, that explains the lower mph. If you gave it hell on the launch and spun, you mph should be higher. On my old race car, if I was on slicks, my mph would be lower than if I was on street tires and spun.
Old Mar 11, 2008 | 10:34 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Your sixty is killing you
Old Mar 12, 2008 | 07:49 PM
BLOWNBLUEZ06
Also if you didn't put your car into performance mode and left the TCS on, you caused yourself some big MPH losses.
Old Mar 13, 2008 | 12:16 AM
whitebullet7
i just got back from wed night drag racing and i did very good tonight.my first passed is 11.928 2.123 60'' 129mph and my 2nd passed is 11.233 1.923 60'' 131.39mph.they don't want me to run lower than 11.50 cause i don't have a rollbar in my car.can i go into 10 with this trapspeed?
thanks guys
Old Mar 13, 2008 | 12:48 AM
Mitch.Shea's Avatar
Mitch.Shea
thanks guys
with some sticky tires.. buy a set of front z06 rims and some dr's and you will get there.. i would upgrade the driveline and put a roll bar in.
Old Mar 13, 2008 | 12:53 AM
whitebullet7
i was on drag pack but i did not launch it hard cause the car still on stock trans and rearend
Old Mar 13, 2008 | 09:30 AM
Corvette-Chris
St. Jude Donor '08
Are you running a brace and hardened output shafts ?
Old Mar 13, 2008 | 01:06 PM
whitebullet7
no i still on stock driveline
Old Mar 13, 2008 | 01:35 PM
Corvette-Chris
St. Jude Donor '08
Thats crazy.....with that much power and DR's, Im shocked you havent broken anything yet. Good luck, as i want to do the same thing
P.S. - Has anyone reached 10's with stock driveline (no brace, stock output shafts) ??
Old Mar 13, 2008 | 02:04 PM
badc51's Avatar
badc51
10.62@ 132 stock driveline, stock output shafts on the fifth run broke my tranny on DR. Now I have RPM tranny.
Old Mar 13, 2008 | 04:44 PM
whitebullet7
how is your tranny from rpm keeping up with your car? cause all my friends with GTO they said RPM tranny is suck.my friend went through 2 rpm tranny in a month.
what hp your car made to the wheels?
thanks
Old Mar 13, 2008 | 08:02 PM
vetterlatethannever's Avatar
vetterlatethannever
..cause all my friends with GTO they said RPM tranny is suck.my friend went through 2 rpm tranny in a month...
Doesn't sound like the RPM we know
Old Mar 13, 2008 | 08:09 PM
blwnc5's Avatar
blwnc5
Not our RPM for sure.
Old Mar 13, 2008 | 08:18 PM
badc51's Avatar
badc51
thanks
My RPM is running great, stage 5 , 575/525 to the wheels 2600 stall.
Old Mar 13, 2008 | 09:59 PM
jpm71's Avatar
jpm71
2nd passed is 11.233 1.923 60'' 131.39mph. can i go into 10 with this trapspeed?
thanks guys
Definitely - my first night in the 10's I ran 10.88 130.2, 6 speed, low 1.7's with drag pack and et streets
To Traps speed question
