Fan temps
Old Mar 15, 2008 | 02:58 PM
TheBigDog's Avatar
TheBigDog
Default Fan temps
If I install a 160* themostate with my TTi Kit what temps do you guys turn fan #1 and Fan #2 on at? It is a daily driver and only gets hammered occasionally...not sure if usage makes a difference, but I want to get the fans set correctly.
Thanks,
The Big Dog
Old Mar 15, 2008 | 04:50 PM
Billf6531's Avatar
Billf6531
Every car is slightly different depending on cooling air flow. Drive on the highway in light or no traffic for ten minutes. What is your coolant temperature (T)? Set fan1 @ T+4 on and T+2 off. Set fan2 @ T+6 on and T+3 off. These values are in Celsius. Convert to Imperial if you need to.
