Need inputs guys
Old Mar 15, 2008 | 07:07 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Need inputs guys
Well Im taking my car to Arnolds.............I cant figure it out! !
Its nor running right! ! I thought one of the injectors was bad and I bought new injectors and its still not running correct! !
Few weeks ago I felt like it was running on 7 cylinders.........all the missing comes from number 2! ! We swapped coils and the problem remained, we swapped wires and the problem remained......so I drove it home and all of the sudden was ok and running like its supposed to..I even got under boost hard and it ran fine, but it did it again after I restarted the car that afternoon! ! I really dont think its internal because it would have never run like it did that afternoon! ! Ive heard it could be the computer or the harness to injector two! ! Can the oil from the breather damage the connectors arounf the coil/injector area on #2? ? ?
Old Mar 15, 2008 | 07:12 PM
mdhmi's Avatar
mdhmi
Plugs / wires ?
Old Mar 15, 2008 | 07:25 PM
SpeedyD's Avatar
SpeedyD
Originally Posted by mdhmi
Plugs / wires ?
I would check the plugs, wires, and if not it can very well be the connector. I had the same issue with the connector but it would drop anywhere from 4 cylinders to just one. Took it apart, cleaned it up, made sure the connections were tight and no more issues.
Good Luck!
Dan
Old Mar 15, 2008 | 07:35 PM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
What a pain Mike Sounds like I have been going through lately. Just keep trouble shooting and you'll find the problem.
Andy
Old Mar 16, 2008 | 10:13 AM
Mike04's Avatar
Mike04
Did you try swapping the plugs, I've had misses similar to that from a brand new plug that was bad.
Good luck with tracking the problem down
Old Mar 16, 2008 | 10:28 AM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
Plugs / wires ?
Same thing happened to me when I put my longtubes on. Its was a plug wire that wasnt fully seated.
Old Mar 16, 2008 | 12:15 PM
M_T_0's Avatar
M_T_0
had simmular problem with #3 went thru new injectors, swaped coils, new plugs and a lot of head scratching. finnaly looked at the o2 and found a bad 1, then got under car and found that a connector had melted to the long tubes and was intermitantly shorting out. The shorted O2 would run 1 bank of cylinders rich to the point of fouling #3.
every time I would retune it, it would run like a champ untill it relearned the LTFT's
More Than Zero
Hope you find it.
Old Mar 16, 2008 | 12:56 PM
BlckC5's Avatar
BlckC5
plug wire touching header?
To Need inputs guys
