ECS and A&A both make a piece for this. To my knowledge they are hard plastic.
The A&A setup is what I have and I purchased the spacer kit to lower the radiator. It did not work to well for my app. as I have the bigger rad and ended up cutting the supports and moving the rad forward some. If I had the stock rad I think it would have been fine.
My understanding ECS sells the complete radiator cradle prefabbed and ready to bolt in. I dont know if it comes with the intake plastic to go over the radiator contact them...
I think andy sells a intake piece that is meant for stock height radiators.... but i think it requires his newer brackets as the headunit may be raised a bit more then your setup.
Matt, if you look at your pic you'll find it's a piece of 4" silicone tube cut on an angle.
I didn't like the looks of it when I put mine on so I took the ProCharger air bridge and used that for the blower inlet.
The only thing you need to do is find a couple of pieces of 4" steel tubing and install it both ends of the air bridge so it won't collapse when you tighten the clamps.
I would just buy Roto-molded piece from A&A. Although its designed for 3.5" diameter inlet it will work fine with your 3.75" inlet. He uses them with T-trim and same diameter as your P1SC... Also you do not have to lay down radiator which is a big plus.
I believe he will sell it to you for $150-175.
Mike
Thanks fellas! That is what I was going to do next!
I was going to call A&A and see if they had the offset piece!
I had another member PM me saying he has the coupler and the pipe and he'll let it go to me!
I got your PM about the pipe and coupler!
So just let me know and do you have a pic of the set-up! You can PM that if you'd like
