Spark plug options?
Old Mar 22, 2008 | 09:39 AM
SlickVic's Avatar
SlickVic
Default Spark plug options?
I currently run the TR6's and wanted to see what if any other plugs some of you might be running?
Thanks in advance
Vic
Old Mar 22, 2008 | 10:40 AM
Jeffs FRC's Avatar
Jeffs FRC
While I was at Speed the other day Larry recommended the TR7's. The electrode doesnt sit as "deep" in the cylinder as the 6's.
Old Mar 22, 2008 | 12:25 PM
leojnknsC5's Avatar
leojnknsC5
ac-delco r42lts
autolite 104 or for a really cold plug the 103.
Old Mar 22, 2008 | 12:36 PM
blwnc5's Avatar
blwnc5
Thanks in advance
Vic
Last I heard you don't need spark plugs on a show car Vic. LOL
Old Mar 22, 2008 | 03:31 PM
Jeffs FRC's Avatar
Jeffs FRC
Oh boy, I can see the showdown at Byron now...
Old Mar 22, 2008 | 03:52 PM
chriswtx's Avatar
chriswtx
Something I found a while back...
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
(one step colder)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
(two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
(two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
(three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
(four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
LS1 w/ Edelbrock and Dart Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations: approx under 9:1 compression
Heat Range: 4
Gap: Consult ignition mfg.
Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
MFG Recommendations: approx 10.5:1 compression
Heat Range: 5
Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
Old Mar 22, 2008 | 07:04 PM
philsy's Avatar
philsy
Great info Chris
Old Mar 22, 2008 | 07:29 PM
lucky131969's Avatar
lucky131969
Thanks in advance
Vic
Vic,
Talked with Mitch at FLP yesterday to get an appointment for my tune. He told me to put in TR6's in before I bring it down.
Old Mar 22, 2008 | 08:21 PM
birch64's Avatar
birch64
Originally Posted by philsy
Great info Chris
Old Mar 23, 2008 | 10:40 AM
blwnc5's Avatar
blwnc5
Originally Posted by lucky131969
Vic,
When are you going in Mike, I might take a ride out there.
Old Mar 23, 2008 | 01:25 PM
lucky131969
Not till May 7th , but they think something will open up sooner. I let you know. Maybe we can get a few guys together and tailgate
Old Mar 23, 2008 | 09:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
(one step colder)
Heat Range: 6
Gap: .035 - .038
(two steps colder)
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
(four steps colder)
Heat Range: 10
Gap: Consult
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Heat Range: 4
Heat Range: 5
Heat Range: 8
Heat Range: 9
Heat Range: 9 - 10
Heat Range: 10
WOW! Great information here!
I will keep this for my usage
Thanks,Matt
Old Mar 23, 2008 | 10:22 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I am running a different plug for the #7 heat range. These are what I use: NGK BP7EFS stock #3526
Old Mar 24, 2008 | 09:15 AM
blwnc5's Avatar
blwnc5
Let me know Mike, It's always a fun ride out there, May 7 will be here soon,
To Spark plug options?
