anyone using interceptor gauge
Old Apr 3, 2008 | 02:37 PM
alzo6's Avatar
alzo6
Default anyone using interceptor gauge
just wondering if anyone is using to obdII monitor gauge from aeroforce/its called the interceptor. i wanted to see how good it is before i bought it and if anyone is using it w/ a fi car. thanks
Old Apr 3, 2008 | 02:43 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
NemesisC5 (Scotty) is running one. PM him for more details.
Old Apr 3, 2008 | 03:19 PM
Corvette4ever's Avatar
Corvette4ever
I have one which I got from FLP. I also hooked the output my wideband O2 sensor to the input of that gauge, so that I can monitor the A/F ratio at all times
Old Apr 3, 2008 | 03:31 PM
alzo6's Avatar
alzo6
does it show boost?
Old Apr 3, 2008 | 04:41 PM
Corvette4ever
If your MAP sensor can read boost then yes, it will basically show whatever the MAP sensor is seeing. Otherwise if you're running the stock MAP sensor, then the only way for this gauge to show boost is to have a second MAP sensor (that has 0-5 volt output) T'ed with the intake manifold, and have it's output connected to the input of the Interceptor gauge
To anyone using interceptor gauge
