RPM Cam only Procharged Z06
Old 04-10-2008, 02:02 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Default RPM Cam only Procharged Z06
2003 Z06
Kooks 1 3/4 headers
Catted X-pipe
Corsa Pace Car Catback
232/240 on a 115 Cam
D1SC on 8PSI
Spec 3 Clutch
it made 661hp 548 tq on a mustang dyno.
Old 04-10-2008, 02:35 PM
FLATOUT
Temporary Hold
FLATOUT's Avatar
Location: www.modular-concept.com www.flatoutimaging.com
Originally Posted by Frans96ss
2003 Z06
Kooks 1 3/4 headers
Catted X-pipe
D1SC on 8PSI
Spec 3 Clutch
Holy Crap
Big Power!
And this is on a stock bottom end?
Old 04-10-2008, 02:38 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Originally Posted by FLATOUT
Holy Crap
Big Power!
yes 100% stock motor internally except the cam... has about 16 degrees of timing in it...
Old 04-10-2008, 03:57 PM
Z06PSI
Z06PSI's Avatar
St. Jude Donor '17-'18-'19
How much meth?
Old 04-10-2008, 04:20 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Originally Posted by Z06PSI
How much meth?
non actually.
Old 04-10-2008, 05:03 PM
Morzoff
Morzoff's Avatar
2003 Z06
Kooks 1 3/4 headers
Catted X-pipe
D1SC on 8PSI
Spec 3 Clutch
That is crazy numbers # I have a cam only blower set up and I'm at 589rwhp
661rwhp on a mustang Dyno is over 700 and other dyno's ( Dynoject, Dyno pack)
Old 04-10-2008, 05:37 PM
vetterlatethannever
vetterlatethannever's Avatar
That's a lot of power, congrats
Old 04-11-2008, 12:36 AM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,099 Likes on 810 Posts
That is sweet on 8 psi post a chart for us to oggle over
Old 04-11-2008, 07:26 AM
PeteZ06
PeteZ06's Avatar
St. Jude Donor '07-'08-'09-'10-'11
Are those rear wheel or flywheel numbers?
Old 04-11-2008, 07:37 AM
Z06PSI
Z06PSI's Avatar
non actually.
Very Impressive.
Old 04-11-2008, 08:49 AM
MotleyDrew
MotleyDrew's Avatar
Something seems odd as i was using 9.6 lbs of boost, more timing with not quite as big of cam in my last setup and made 503rwhp on a mustangdyno. Not sure how you were able to get to that number? Did you put the car in as weighing 6000lbs?
Old 04-11-2008, 09:32 AM
Sponge Vette
Sponge Vette's Avatar
St. Jude Contributor
Sound like your flagging sign. The numbers do seem a bit high for a stock motor, interesting to see how long it last if he continuous running those number.
Old 04-11-2008, 09:46 AM
FRCTony
FRCTony's Avatar
I'm not buying any either
Old 04-11-2008, 12:27 PM
Drewstein
Drewstein's Avatar
I ran a very similar cam and a D1 on a stock head/bottom end LS1 and made 641rwhp on 91 octane without meth/alchy garbage.
If it weren't for the mustang dyno part I would say they are very believable numbers. On a dynojet that would be 700+ on the stock bottom end and without 109 it's going to last 2 pulls IMO.
Old 04-11-2008, 01:02 PM
HIGHRPM
HIGHRPM's Avatar
With only 8psi boost,stock heads and internals, no meth, the numbers seem about 75-100rwhp too high.
Old 04-11-2008, 01:10 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
well the car made 603 before the cam and i use this dyno for EVERY car i build and all the other numbers on cars i build are 100% accurate so it leaves me no choice but to beleive these.... i dont really know how to make you guys beleive it but if you wanna go for a ride in the car i can arrange that with the customer... b/c it RIPS
Old 04-11-2008, 01:37 PM
PeteZ06
PeteZ06's Avatar
To RPM Cam only Procharged Z06
Old 04-11-2008, 01:48 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
rwhp... i would never state flywheel numbers. thats kinda pointless in a way i think... unless you are using and engine dyno.
Old 04-11-2008, 02:24 PM
black98c5
black98c5's Avatar
That car is laying down some freakish numbers for ONLY 8#.
Old 04-11-2008, 03:16 PM
95BlueBomber
95BlueBomber's Avatar
I'm Selling my car
Must be a VERY giving Dyno
Quick Reply: RPM Cam only Procharged Z06
