Sts Oil Return Proposal
Old Apr 23, 2008 | 12:54 PM
hak's Avatar
hak
Default Sts Oil Return Proposal
I am not happy with my oil STS return to the oil fill cap . It looks like crap and it came off on me once and spit oil all over the engine. I know that for the C6 STS drills and taps both valve covers to return the oil.
I am think of doing one of the following, but want to get some feedback from the group.
1. Drill and tap only the right side valve cover for the return oil.
OR
2. Eliminating the oil level indicator in the oil pan and returning the oil directly to the oil pan. If I use this method, how do I prevent the warning system constantly screaming at me ?
Has anyone tried either of the above mods with any success?
Is there another way to do the oil return without drilling and tapping the oil pan ?
Old Apr 23, 2008 | 01:23 PM
RoadRebel's Avatar
RoadRebel
Drilling and tapping one side is the equiv to what you have now without the issues and sillyness.
There is another option I forgot about, and that is to use the dipstick. Similar to what ECS and A&A used to use. Its a modified dipstick tube near the bottom with a fitting welded to it for the return oil.
Phil
Old Apr 23, 2008 | 05:56 PM
hak's Avatar
hak
Thanks Phil,
The tune you did is great. I love the way the car drives .
Old Apr 23, 2008 | 11:45 PM
thetoy's Avatar
thetoy
OR
I had a sts system installed 2 months ago on my 99 c5 he drilled and tapped both valve covers It works great and I love driving the car.
Old Apr 24, 2008 | 12:07 AM
oupike1757's Avatar
oupike1757
Why not put a "t" fitting at the oil level sensor?
Old Apr 24, 2008 | 12:58 AM
bullitt4110's Avatar
bullitt4110
On the APS kit the return line has a barbed fitting that is tapped right in the valve cover right below the oill filler. That would accomplish the same thing as it is now, while not having to deal with the cap anymore.
Old Apr 27, 2008 | 10:11 PM
Jesse_Boyer's Avatar
Jesse_Boyer
When I had mine, I tapped my passengers side valve cover and used a 1/4" NPT fitting with a quick connector for easy removal.
Old May 4, 2008 | 08:13 AM
hak's Avatar
hak
Thanks for the advice. I have tapped the passenger side valve cover with 1/4 NPT and run my return line to a 90deg NPT to hose fitting. Works great
Old May 5, 2008 | 01:31 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
ECS deilled and tapped my oil pan
To Sts Oil Return Proposal
