misfire?
Old Apr 29, 2008 | 05:35 PM
lucky131969's Avatar
lucky131969
Default misfire?
Runs very strong.
Old Apr 29, 2008 | 06:06 PM
leojnknsC5's Avatar
leojnknsC5
The difference between open and closed loop is the front O2 sensors. I'd look at what the O2 readings are on a scanner when the rpms drop. Also, if you have a wideband AF gauge, what is it showing?
What is timing doing when the rpms drop?
Old Apr 29, 2008 | 07:15 PM
leojnknsC5's Avatar
leojnknsC5
Could it be just normal backpressure popping?
Old Apr 29, 2008 | 07:42 PM
leojnknsC5's Avatar
leojnknsC5
Its possible that the drop is caused by the Throttle Positioning Sensor or TPS. The computer adjusts timing and throttle position to arrive at an operating idle rpm. The throttle is moving open and closed to maintain engine rpm. If it doesnt cause any other problems, ignore it.
Make sure your BOV boost outlet valve is operating like it should. A bad BOV will wear out a throttle body pretty quick.
Old Apr 30, 2008 | 06:59 PM
leojnknsC5's Avatar
leojnknsC5
If it gets worse, the throttle body may be sticking or the throttle motor may have issues.
Old May 6, 2008 | 02:19 PM
SLPRC5's Avatar
SLPRC5
Hi Lucky,
Today I went back to my installer/tuner Robert at Advanced Dyno here in NorCal. (great shop and a great guy)
He got my misfire out by taking out timing. I'm running 14* of timing and that seems to have taken care of the misfire of 100 RPM. My idle is at 650/675 RPM. It idles great for the A4.
This may help your situation.
Good luck
Thanks for all the input on this issue.
SleeperC5
To misfire?
