6 speed scattershield installed !
Old May 1, 2008 | 06:50 AM
highpockets's Avatar
highpockets
Default 6 speed scattershield installed !
Finally got my trans/diff out to add the hardened output shafts as well as install the quicktime C5 scattershield. Very tight fit,had to machine lower part of spacer/block plate to clear the allen bolts protruding from the back of my Tex twin clutch setup.Also,bolt this to your torque tube to verify clearance/grind as needed for the clutch bleeder,I found it tight as well.Perhaps the remote bleeder would be in order.Anyway,very happy to have it in and not worry about any safety issues with the clutch now .Thanks !
Old May 1, 2008 | 08:30 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Looks real good!
Thanks,Matt
Old May 1, 2008 | 04:29 PM
Vince99FRC's Avatar
Vince99FRC
It is good to see we finally have one. After my old clutch explosion I still wonder when the clutch is going to come through the floor again.
Old May 1, 2008 | 08:50 PM
highpockets
Yup,I feel better having one myself. I held off until now installing my output shafts so I could do it all at once.Sent my turbo housings back to Nick to get ported as well and installed my Jesels.It has been a busy couple days !
Old May 1, 2008 | 09:17 PM
Vince99FRC's Avatar
Vince99FRC
You are busy!! I opted to keep my turbos as is. Per a post from Dr. Phil there is no need for me to have mine done since it does not hurt my setup. I wont be going down in boost. Only up..
Old May 1, 2008 | 09:30 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is awesome and something to upgrade when my driveline comes out next time
Old May 1, 2008 | 11:13 PM
highpockets
Since I am only running a 402 and some stock truck heads,I figure I need all the help I can get I plan to push it a little too this year,I have been very happy with this setup so far ! Good to talk to you again,have a great day !
Old Nov 30, 2008 | 11:53 PM
2MuchRiceMakesMeSick's Avatar
nice. where did you get it and how much was it?
i want one for my car
Old Dec 1, 2008 | 12:52 AM
highpockets
I think I got it from DTE when they did a special deal after they first came out.VERY tight fit,needs a little cleanup grinding on the clutch bleeder as I remember or possibly a remote line.Seemed like it was about $400 bucks,or so.If you cant find it PM me and I will dig through my file of receipts.
Old Dec 1, 2008 | 05:01 PM
I have a remote bleeder and the motor is almost ready to drop in the car so I will have to look soon. I dont mind girding a bit although for 400 bucks it should fit like a glove but not having one of these is not a good idea.
Old Dec 1, 2008 | 06:27 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
I saw a guys clutch come through the floor on one of the PINKS shows...
Man ..not good....good idea you have there !!
It put a huge hole up through the floor...
Absolutely scary !
Old Dec 1, 2008 | 09:06 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
RPM can get you one of these.
I installed one of their C5 ones and did not have to do any grinding on the housing itself. There were some clearance issues on the back plate with the tex twin, none with the OZ700 I had on the car.
Bleeder did require a little tweeking but no grinding.
Not the easiet thing to fit in there but worth the work if you are concerned about the clutch coming through the floor.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Dec 1, 2008 | 09:31 PM
I have the tex twin disk. Can you tell me more about the clearance issues. Will it not work at all?
Old Dec 1, 2008 | 09:34 PM
BLOWNZO6's Avatar
BLOWNZO6
No it will work with no problem, it just takes some modification.
You have to clearance the back plate that goes behind the flywheel.
Removal of the clutch assemble and the flywheel is necessary for installation.
Maybe Vince took a picture of what he did to clearance it? I have not actually done one myself with the twin, just know of three that were installed and all had to do the same thing.
To 6 speed scattershield installed !
