Replacement Lifters
Old May 1, 2008 | 07:54 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default Replacement Lifters
I'm running LQ-9 heads with a .600 lift cam. I'd like to replace my lifters. What's everybody running? Should I go with another stock set?
Old May 1, 2008 | 08:19 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I have the LS6 lifters in mine!
But I hear that the Cadilac Lifters are the way to go.
For my application the LS6 lifters are perfect
Thanks,Matt
Old May 1, 2008 | 08:39 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I am rebuilding my engine and LME is doing all of the machine work. They recommend LS7 lifters. I have looked everywhere and sdparts.com ( scoggins and dickey ) has the best price at around 108.00 a set.
Old May 1, 2008 | 10:14 AM
chriswtx's Avatar
chriswtx
running LS7 lifters here..got them at sdparts.com
Old May 1, 2008 | 10:40 AM
bullitt4110's Avatar
bullitt4110
I have the GMPP CTS-V race lifters
Old May 1, 2008 | 11:09 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Same here...prior to that I was just using my 01 stock LS6 lifters....I only changed them because I did a refresh on the motor last year and they were only like $120 to my door. The only reason to buy the CTSV "Caddy" lifter is if you intend on reving your motor to 7K+ rpms. They were developed because of the CID requirement and the only way to ring more power out was to increase the RPM...so they work really well. But interestingly when I compared the picture of them to my original LS6 lifters they looked very close to the CTSV lifters..both were significantly different then the newer model LS1 lifters used from 2003+...I may be wrong on the year. The new LS7 lifters are the standard LSx replacement lifter and is what I am currently using.
I haven't had any issues using either of them.
Old May 1, 2008 | 11:38 AM
Boob's Avatar
Boob
If I'm not mistaken there is no difference in the current LT1 vs. LS1 vs. LS7 lifter. The Caddy Racing Lifter has lighter internal parts, and revised oil passages.
I'm running the caddy lifters. No complaints, which is just the way it should be.
Old May 1, 2008 | 12:52 PM
Stangkiller
Looks like the Caddy racing lifters
To Replacement Lifters
