Split fuel trim with Maggie setup
Old Jun 3, 2008 | 11:31 PM
  #41
muncie21's Avatar
muncie21
I'm running a maggie and have the same issues...passenger side lean condition between 2000 and 2300 RPM.
On my engine, it only occurs once the engine is warm. Even in closed look, with a cold-ish engine, it runs fine.
Interested to hear what you guys did to fix the problem.
Old Jun 4, 2008 | 07:54 PM
  #42
RED99's Avatar
RED99
Could these 60# injectors be hurting my fuel trims at cruising 2000 rpm? They are only open about 1.5- 1.6 ms.
Old Jun 4, 2008 | 11:00 PM
  #43
muncie21's Avatar
muncie21
I'm running 42's and getting the exact same problem, so I'm not betting on the injectors. I'll post a log of my fuel trims if I can find it.
Old Jun 6, 2008 | 08:34 PM
  #44
INTHERED's Avatar
INTHERED
Did you guys know that there is a balance tube available that attaches to the rear of the Maggie fuel rail ? The Maggie fuel rail is already pre-drilled and tapped to handle the addition of the balance tube its a simple bolt on upgrade which may help with your problem.
INTHERED
Old Jun 7, 2008 | 12:54 PM
  #45
RED99's Avatar
RED99
I could see that being a problem if it was a constant problem. But mine comes and goes.
I would think the fuel rail is tapped at the end because it's an extrusion.
Old Jun 22, 2008 | 09:44 PM
  #46
vettman10's Avatar
vettman10
Cruise-In II Veteran
MIne does it too - bank 2 lean at 1800 to 2100. I've been chasing it for about a year now and think EC tune is right - its some kind of harmonic. And as such, conditions have to be jsut right to set up, so this is why mine and others experience it more pronounced at times, but primarily when warm, but always at +/- 2000 rpm. I have adusted the VE table with my wide band screwed into the right side exhaust, so it reads the lean side. I even tried off set closed loop fueling between the 2 banks which did help a little. Very frustraiting.
Old Jun 22, 2008 | 09:48 PM
  #47
muncie21's Avatar
muncie21
Just to mix things up a bit, I'll add this....
My maggie only does this when it is warmed up.
When the motor is cold-ish, the lean spot does not appear....even in closed loop fueling. Once it gets hot, it sticks out like a sore thumb.
Old Jun 22, 2008 | 10:05 PM
  #48
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I wonder if a SD tune would fix it.
Old Jun 22, 2008 | 10:22 PM
  #49
muncie21's Avatar
muncie21
Happens with the MAF plugged in or not.
Old Dec 3, 2008 | 03:09 PM
  #50
95BlueBomber's Avatar
95BlueBomber
I am in the same boat
Where is this balance tube found? I would be willing to try it
Old Dec 3, 2008 | 07:01 PM
  #51
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Might as well throw mine in the mix. Same problem.
Old Dec 3, 2008 | 08:13 PM
  #52
BLOWNBLUEZ06
You might call Callaway and Magnuson. You should be able to make one with some 90's and braided line. If I remember correctly, both ends of the fuel rails are tapped, so you just need to connect the ends to balance the fuel pressure if I'm understanding the issue.
