ECS Blower Cam
Old May 31, 2008 | 09:30 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default ECS Blower Cam
Well my 408 Iron Block is coming together, I called Chris at ECS and order the cam, he recommended the big blower cam! !
Dont ask specs because I have no clue!
Old May 31, 2008 | 09:39 AM
vr6aaron's Avatar
vr6aaron
I ordered one too, I wish I knew the specs also. I do think its on a 115lsa and should have some lope.
Old May 31, 2008 | 12:36 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Who cares about the specs! ECS's cams work!! Cant wait to see the new numbers!
Old May 31, 2008 | 12:44 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old May 31, 2008 | 01:07 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by FactoryRaceCar
+1
Old May 31, 2008 | 02:26 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by peter pan
+1
+2
Old May 31, 2008 | 03:07 PM
rplaster's Avatar
rplaster
Anyone have a before and after numbers with thier cam?
Old May 31, 2008 | 05:59 PM
Carl Spackler's Avatar
Carl Spackler
St. Jude Donor '08
EG's Whiplash cam and and pulley swap from 4.10 to 3.85 took my P1SC-equipped mn6 from 430rwhp to 507rwhp.
Old May 31, 2008 | 09:34 PM
Mike04's Avatar
Mike04
With my A&A cam I went from 530 rwhp to 595 rwhp, I'm sure the ECS cam would be impressive also.
Old May 31, 2008 | 10:13 PM
mdhmi's Avatar
mdhmi
Grats on the new cam.
Old Jun 1, 2008 | 07:00 AM
stevieturbo's Avatar
stevieturbo
I do...I could never buy a cam without knowing.
For all you know, you could be buying a cam exactly like you have already.
Old Jun 1, 2008 | 09:18 AM
2003VETT's Avatar
2003VETT
Not from ECS. Thats whats nice about being able to trust your vendors and tuners. I personally know all of these guys and see what goes into their R & D for these products. They go through hell to find combinations that work.
Old Jun 1, 2008 | 11:41 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Ditto
Thats kinda like buying heads without flow numbers, hey trust me, they flow good
Old Jun 1, 2008 | 05:11 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by PeteZ06
Ditto
yeah then the guys take the cam specs and have comp cams grind it for them for only 200 bucks. thats why tuners dont give away cam specs... to avoid immitators and other tuner shops that will just copy them and sell them for less.
Old Jun 1, 2008 | 06:02 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Ditto
Hmm, yeah some people need to compute things like SCR and DCR too when they are building a motor.
It makes power, but I cant buy something without knowing what it is sorry. Marketing is key in this world .
Old Jun 1, 2008 | 06:05 PM
stormrider's Avatar
stormrider
http://forums.corvetteforum.com/show...&highlight=cam
I am going to use this cam for my H/C upgrade
Old Jun 1, 2008 | 11:06 PM
vr6aaron's Avatar
vr6aaron
I want some numbers for the 402 blower cam. Anyone out there have one?
To ECS Blower Cam
Old Jun 2, 2008 | 08:29 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
with all due respect we do ask what cam a customer is presently running and if its close to ours we tell them to just leave it in there.
Old Jun 2, 2008 | 10:17 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Please tell me who at Comp charges $200-I'll buy a dozen cams off him right now!
Old Jun 2, 2008 | 10:26 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Ditto
I have a friend that has specialized in the LSx engines since they came out. Early on, he had a head company charging around 2200 bucks for a set of heads. In the pursuit of comparable power for less money, he took one head to 2 head porters and told them to match the port work, valve jobs and flow #'s. They both matched everything and on the dyno the expensive heads still made 30 more rwhp. Can't explain it. Saying " trust me" with a highly regarded tuner / performance shop is no issue with me. If I trust them, I don't care what the heads flow as long as it gets the desired result.
