Methanol Question
Old Jun 6, 2008 | 09:56 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Default Methanol Question
I filled my washer tank with meth, and the vehicle will sit for a week or 2, I go to drive the vehicle and it tells me Low Washer Fluid. WTF what happen to the Meth in the tank? Does it evaporate, I don't see anything leaking in the garage. Also does the car only use the meth under full boost when the green light comes on? Just driving around town I might be on boost a few times and let the car sit just to have to fill the tank again. Oh and this is a ECS Methanol system.
Old Jun 6, 2008 | 10:28 AM
95BlueBomber's Avatar
95BlueBomber
My car always says low washer fluid even when full of methanol
AlwaysInBoost's Avatar
AlwaysInBoost
meth will evaporate, just like gas, over time.
how much you spray and when you spray it depends on how your system is setup & installed.
Old Jun 6, 2008 | 10:43 AM
Sponge Vette
I've got a single nozzle, with the controls set at 6.5 I would of thought it would last a few tank of gas. It must really evaporate fast?
Old Jun 6, 2008 | 10:57 AM
HP_Addict's Avatar
HP_Addict
You should check for leaks. It should not evaporate that quickly.
Old Jun 6, 2008 | 12:43 PM
corvettebob1's Avatar
corvettebob1
Either you have a bad level sensor or it's installed upside down.
The flat next to the grommet should be at the top.
Old Jun 6, 2008 | 12:46 PM
corvettebob1
You have a leak, check the around the grommet for the level sensor and the washer pump.
Meth will evaporate very quickly but will leave a trail on the frame rail.
Old Jun 6, 2008 | 01:25 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have let my car sit for months with little to no loss of meth, check for leaks. Once it leaks it will evaporate fast so you may not see any puddles from it.
Old Jun 6, 2008 | 02:24 PM
FreddyG's Avatar
FreddyG
I stored mine for the winter and when I took it out of storage (2.5 months later), there was still meth in it.
Old Jun 6, 2008 | 06:28 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Make sure your sensor is turned right side up!
There is a groove cut out of it and it will be facing upwards
I had mine upside down at one time so it's worth the check see
If you Meth has a small leak it will evaporate perhaps before you can detect it.
Fill it and look all around the pump amd fittings with a good light and check for seepage
The Meth "ONLY" comes on under B@@ST and should not squirt while you are doing regular driving if it did you would be running pretty rich and the motor would stumble
Thanks,Matt
Old Jun 6, 2008 | 08:19 PM
Sponge Vette
Thanks guys, I definitely have a leak some where. Does anyone have a hard time starting the car from time to time because of the Meth, almost like vapor lock, the car starts and run like it's on 6 cyl, I'll turn it off and restart it a few times and it seems to clear up. Very annoying
Old Jun 7, 2008 | 01:15 AM
Ilovechevymusclecars's Avatar
It almost sounds like the meth is siphoning into your intake and pooling up.....because you said your having problems with the car idling.
BTW this is just a guess.
Old Jun 7, 2008 | 02:30 AM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
A very good guess at that. Do you a check valve installed that is working?
Your right by Phil, have him check it out for you.
Old Jun 7, 2008 | 10:20 AM
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
Same problem I had hard starting and tank empty. Found one check valve stuck open.
Old Jun 7, 2008 | 10:27 AM
95BlueBomber
yep sensor upside down... thats why I love this forum!!!
Old Jun 7, 2008 | 03:30 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I have the “low washer fluid” every time I start my car. The tank is full of meth; I got a new sending unit and it not upside down. Is there a way to check this out without getting another sending unit? I know the new one could be bad also, but I don’t want to buy another if that is not the problem.
Thanks,
Clayton from Las Vegas
To Methanol Question
