well right now makes 515rwhp, would love close to 600, have p1 charger with stage 1 bracket and intercoolers, spec stage 2 clutch, lg longtubes, borla stinger exhaust, what should be next to meet my goal
ya really feeling the cam route, should i do heads along with it, along with basically a complete top end, have 6.5 psi right now not 100percent on the pulley size, the one that came with the charger, where can i buy the stage 2 kit other than procharger directly
What RPM do you hit peak power? If you have a dyno chart please post, Also where did you get it tuned?
rpm is stock redline 6700, dont have a dyno sheet, car was tunned in orlando at corvette master
Your factory heads are great, however a good blower cam along with new dual valvesprings will make a big difference (usually 50+ RWHP on an FI build). Aditionally going one size smaller on the head unit pulley with the cam swap will add even more power without adding much extra cost. However after crossing the 550rwhp range and into the 600rwhp+ range the expense and risk go up with the need for alky and the fact that your stock bottom end is "Living on the Edge" Good Luck Brudda
