FI Experts, Come inside Please!!
2003 Z06, black with mod red interior. Let me first say that you WILL NOT find a stock paint C5 that looks this good. I have spent hours and hours polishing out the black paint and have this car totally dialed in.
I think there is one nick on the hood and other than that, the paint is basically perfect. There are literally NO SCRATCHES OR SWIRLS on the car. It really looks unreal. The black is just as deep and glossy as some paint jobs I've seen on much higher end cars and show jobs. It looks like you can dive right into it.
Just hit 18,000 miles. Clear title, no accidents, no paint work, no issues or stories.
MODS include:
A&A Procharger kit with front mount intercooler, upgraded Vortech blow off valve from A&A, upgraded injectors from Andy, upgraded spark plugs and a lowered thermostat, Dewitts radiator, Textralia OZ700 clutch, Kenne Bell Boost-a-Pump, Lingenfelter hardened output shaft, Autometer fuel pressure and boost pressure gauges in A-pillar pod, mesh screens over the rear exhaust areas and lots more. I'll add more as I think about it.
I have the A&A invoice as well. All parts were bought new and installed by the prior owner, also a forum member. No short cuts were taken -- this car was built perfectly and runs flawlessly.
TUNING was done by HP Tuners and was performed by Phil, known across the country as possibly THE premier tuner on boosted Corvettes. The tune is, as you would guess, FLAWLESS. The car runs like a stock car until you get on it. No surging, no bucking, no overheating issues at all, especially with the Dewitts radiator.
The Z made 547.4 horsepower at the rear wheels. That was through an entirely STOCK exhaust!!! (I have in my signature that I have LG longtubes and a full 3" exhaust. This has never been installed. It's going on the next car I think.) This car is a major sleeper. You can just slightly hear the blower whine. Other than that, you'd never know that the car has close to 650 horsepower!!!
Give this newbee some insight and am I getting in over my head or is this a well built car? I was told it was tuned on the conservitive side to be safe and run fine on 91 if need be. We have 94 here so that shouldn't be an issue.
here's the dyno chart,
I would NOT buy it if the seller is trying to recoupe all of his costs on the build. Cause if that were the case, you could do it yourself. I do not believe a properly built car is devalued by its aftermarket parts, but I do believe they can EASILY be overvalued..
If the price is in line with what your comfortable, jump on it!!
But..... Be smart. Check for leaks in the blower, signs of blowby, do a wet and dry leakdown, visually inspect the valvetrain, and top it off with a compression test..
JMHO
Thanks guys and stay tuned...
Tyler
Does anyone know what P1SC runs at (PSI)??
Thanks,
Tyler
