Burning plug wire.
Old Jun 22, 2008 | 11:34 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Default Burning plug wire.
I have a problem with a plug wire on my single turbo.With a 90 or straight end it eventually burns the wire against the header.I've tried the woven insulating sleeve and header wrap and the sleeve will be next.Does anyone have a solution?Sure wish they made plugs in different lengths .
Thanks.
Old Jun 22, 2008 | 11:55 PM
AVB's Avatar
AVB
fire sleeve inside a cool sock seems to be holding up for me..
Old Jun 26, 2008 | 02:03 PM
AlexB333's Avatar
AlexB333
Thanks.
Is the wire burning or the boot? I had these issues with the boots on my TT setup and I found ceramic plug boots made by Jacobs. They are pricey, like $180 for a set of boots but they are good for 2000 degrees and work nicely. Summit sells them.
Old Jun 28, 2008 | 01:56 AM
396375's Avatar
396375
Great.I saw these years ago but didn't know they were still around.
Old Jun 28, 2008 | 08:16 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I've made a sheild in the past for the wire.
Simply cut a small piece of sheet metal to go around the plug wire and longe enough to bolt onto something to support it
Thanks,Matt
Old Jun 29, 2008 | 12:37 AM
396375's Avatar
396375
Thanks.My plug boot has barely enough room for the woven heat shield.It's that close.I'm moving up to a bigger turbo this week.I'll add some extra clearance when I get it apart
Take care.
Thanks,Matt
Old Jun 30, 2008 | 12:44 AM
BlackSun!'s Avatar
BlackSun!
To Burning plug wire.
