Mezzier 55 gpm working GREAT for 3 years - Needed it for "Staging Lane Heat Mgmnt." Its wired to the ignition. Also have a fan relay ground switch so I can run the Spal fans at will. With all my electronics (KB BAP, Magna Fuel Pump, Fast WB, AM Backup Tach, 2 Pod Gauges, Radio, etc.) and the lights on I need 92 Amps. hot. Start up cold, lights off 63 Amps.
They don't last very long, nowhere close to their mechanical counterparts. Also, they don't give any warning when they die, they will suddenly take a dump, leaving you at the side of the road. They definitely make sense for a trailered track car, but not for my daily driver.
...and the big downside is flow rates and volume, especially at high RPM
Back to back runs with my Maggie at high rpms I have never seen any spikes in coolant temps.
Obviously a mechanical pump will flow higher rates at high rpm compared to low but the radiator can only cool a certain volume.
Higher flow does not necessarily equate to cooler temps.
The faster the coolant passes through the radiator the less heat is taken out. So it's also a matter of determining the optimum flow to maximize cooling.
Also the flow is restricted at the t-stat so at a some point the volume does not continue to increase buy the pressure in the block will.
Maybe the key here is sustained high rpm's moving a higher volume of water that can be cooled better with higher velocity windspeed through a high performance radiator core on a roadcourse. Another consideration with the Evans unit is their coolant and how they claim it differs from standard Prestone or Dexcool.
I have experienced the issue of a high volume pump inadequately cooling on an old Chevy smallblock with factory radiator. I switched back to OEM replacement and operating temps were down as before the "more is better" swap. In some cases more is better, but as we all have experienced, higher performance needs matched components to truly perform. I just cannot see that a high volume water pump is "snakeoil" for as long as they have been in existance, everything has it's proper application
The best coolant is 100% distilled water. Some people believe running a higher percentage of Dexcool will yield lower temps.
Coolant mixes are only for corrosion resistance and to protect against freezing.
Testing by Evans shows that we need 55 GPM at high RPM or sustained high loads to adequately cool our motors.....especially critical in the back cylinders - No's 7&8
E-pumps are presently providing 25 GPM - who knows, maybe someone will introduce a BLDC e-pump that can increase RPM/Flow through feedback from throttle position, ECT's, MAP, etc..
Using an Evans mechanical pump in conjunction with a Dewitt or other similar radiator is my recommendation.
What was the definition of "sustained high rpm" criteria in the tests
Interesting thread, I had heard mechanical water pumps cannot be built to funtion well at both high rpm and low rpm because if the vanes of the pump are agressive enough to pump well at low rpm they will cavitate at high rpm. They will be trying to take such a big bite of water they will leave a void behind them, a pocket that will be empty bite for the next vane. If you built it to perform well at High RPM it will not work well at low rpm, not move enough water. That's when E pumps started to make sense to me. I know by the end of the 1/4 mile I have increased temps but it quickly cools back down on the return road...
Great thread
Steve
Assuming good optimal airflow management, evans pump and big radiator is as good as it gets... it would be optimal, anything else would be less for folks who could benefit from it. Driving in the street and the occasional strip, it'll be "fine".
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We generally only recommend them for the drag guys, nothing better than being able to leave the WP and coolant fans on while sitting in the staging lanes.
I also have one on my own car for this purpose, and have no issue's on the street, but I have not found it necessary for the average guy.
FYI, the Meziere WP for the LS family of engines flows a constant 55gpm as mentioned in the link below. The Evans mechanical pump addresses the high rpm cavitation issue with their own special mix designed specifically for their "system"
go with evans pump and the NPG coolant. You will never overheat I am running this setup and run 215 with ac on in summer
hey nick "why re-invent the wheel".....know where I heard this?
Tom
I have had an Evans pump and NPG+ coolant for over 2 years....never an overheating issue. Even on hot 100+ degree days the highest temp ever seen is 217....usually run in the 165 to 183 range on hot days when cruising.
Call Steve Prestley at Evans for the bypass mod.....it increases flow. The Evans NPG+ has a much higher flash point than water and carries more heat away. Its much better than any water combo.
I'll pose a weird thought here. ( I am NOT an electrical engineer in any way)
What if you ran a BAP to the water pump? Would it pump more water under boost?
I certainly see that on almost any car that if you hold the RPM at 1200-1500 RPM, the temp definately comes down. That tells me that we need more water flow at idle and low speeds. This is where the electric water pump helps.
Would the BAP help at high RPM?
Charlie: You're the electric motor guy. What say you on this?
I know I'm not Charlie, but there's no reason it wouldn't work as long as the BAP can handle the current that the water pump takes. It will put more load on the pump motor though. As long as it's engineered to take a few extra volts and able to shed the heat load, it will work.
I installed my Mez electric WP soon after installing my Supercharger. Its been working great for 3+ years with over 25K miles. The car is my daily driver still as well (most recent dyno is 633 rwhp). I installed a Dewitt's radiator about 1.5 to 2 years ago and this combination has been great with South Georgia heat. Only real problem was a blown fuse at one point but rewired it to a relay and haven't had any problems since.
We did that on Asmokegars old Coupe a few years ago, it worked great. The car would get a little too hot after a good romping or 1/4 mile pass, not over heating, but hot. We put a BAP on the Meziere for giggles since there was one in the car that we were not using, and it helped keep the temps down on high RPM runs.
Imagine that, I never thought I would hear of Andy & Doug "OVERSPINNING" anything but the fuel pump I like that idea, I bet Nouman already has his order in
I am beginning to start a big LSX (430) twin turbo (68's) build and I am trying to decide best way to cool the motor. I hoped this thread would help but it looks like there are two camps on this. Electric WP's are great and Evans (mechanical) pumps are great. My question...if you plan to run on the street not drag or road race and are worried about heat (twins create a huge amount of heat) is electric the best choice or stay mechanical? I know I may create lots of differing opinions but what I would like to hear is from tuners or folks who may
have used both. I can't judge when you only have experience with one type. Tuners would be the best help as they have multiple experience. My builder will do either but my tuner is not a huge fan of electric WP's. Thanks so much in advance!
