Help with SC boost
Old Jun 30, 2008 | 01:59 PM
TKT-MKR's Avatar
TKT-MKR
Default Help with SC boost
Hey guys
Question:
Today it was 93 degrees out with probably 90% humidity
I gave a couple of pulls on my car and noticed that the boost didnt get up to the normal 7.4-7.6 psi it used to but would only maybe go to 6.2
I have a Maggie SC with the 7.4psi pulley on it and a MagnaCooler
Is this something i should be worried about.
If i didnt watch the boost i would have never noticed the difference.
I then later did some pulls in 84-86 degree weather and it still showed 6.2-6.4
what happened to the 7.6 I was running?
The only thing I did was change the thermostat to a 160 degree one, versus the 180 i had in there before
Any ideas?
Old Jun 30, 2008 | 02:16 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Look for black dust around the Maggie pulleys up front and in back. You may need to adjust the tension in the back or you may need a better tensioner like one from ECS. I have one for sale that I only used for 500 miles. PM me if you're interested. Also, make sure your blower/intake bolts didn't come loose. They will blow boost past the intake seals if they come loose.
Old Jun 30, 2008 | 09:03 PM
Vega$Vette's Avatar
Vega$Vette
don't forget to check the gauge too.
Old Jun 30, 2008 | 09:21 PM
TKT-MKR's Avatar
TKT-MKR
well it just seemed weird that suddenly it went from 7.6 psi almost constant to 6.4 psi almost constant
i mean to me that seems more like a setup or tuning problem.
like ie. it was the pulley
since anything else i would think you would see fluctuation and not constants
Old Jun 30, 2008 | 10:08 PM
BLOWNBLUEZ06
I agree with Vegas. The boost gauge might have an equalization screw on the back. You might want to check for that. At least make sure your boost is on 0 when the engine is off. Is there dust around any of the pulleys front or rear? Is your belt glazed?
Old Jun 30, 2008 | 10:11 PM
Vega$Vette's Avatar
Vega$Vette
Mechanical or Electric Boost gauge. Maybe a leak in the vacuum/boost line ?
Old Jun 30, 2008 | 10:28 PM
TKT-MKR's Avatar
TKT-MKR
i think it is a mechanical (its a dakota digital). didnt install it
but i think it is one that t's into the vac lines of the sc.
again not sure
as for dust, i dont know yet. it has been raining here and i havent gotten a chance to go look at the car uncover it or anything.
hell my butt barely got out of this chair today ;-(
Old Jul 4, 2008 | 01:01 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
To Help with SC boost
