Fuel pressue issue
Old Jul 5, 2008 | 04:56 PM
RED99's Avatar
RED99
Default Fuel pressue issue
I have about 4000-5000 miles on my LPE fuel pump. It starts out with 60-62psi, but the longer I drive the car, the less pressure it makes. Last week when it was hot my pressure got down to 54psi.
And I noticed under boost, the pressure stays the same, even though I have my boost-up-pump turned up full.
Is my pump worn out already?
Old Jul 5, 2008 | 06:56 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
Heat will reduce pressure a couple of lbs, as I have found out in Phoenix hot temps, but when my pressure dropped to the low 50's and wouldn't move I started to dig into it. I bought a new sensor, lengthened the line to take it away from the engine and nothing help. I finally bought a cheaper, different brand fuel pressure guage and it's back to 62. So I figure it must have been the Autometer guage.
Old Jul 5, 2008 | 06:57 PM
Mike04's Avatar
Mike04
I would second guess the gauge or sending unit, they are known to wear out (happened to me). I would verify the drop before changing the pump.
Old Jul 5, 2008 | 08:03 PM
RED99's Avatar
RED99
OK, I will check it out then. Or maybe just buy a new sensor, since the sensor probably doesn't cost that much.
Old Jul 5, 2008 | 09:05 PM
Warp Factor's Avatar
Warp Factor
Happened to me (and others) with both LPE and Racetronix pumps since day one. My fuel press gauge has been replaced, (it was defective but problem is still there). Problem has gotten better with time (three years).
My guess is that there are some tight mechanical clearances in the fuel pump which bind when the fuel gets heated. A new pump (same kind) might only make it worse. Tried three so far.
Old Jul 5, 2008 | 11:29 PM
RED99's Avatar
RED99
I wonder if I can put a regulator before the fuel rail and set it to 54psi and tune the motor for that amount of pressue without a negative effect? And would the backpressure on the pump side cause any issues?
Old Jul 6, 2008 | 07:27 AM
Warp Factor
Hmm, sounds like it might work, as long as your fuel pressure doesn't ever go below that. Mine did if I drove it long enough on a hot enough day. Would drop like a rock at max power.
Here's an older thread attempting to diagnose the fuel heating issue, and which also has detailed temperature charts.
LINK
Old Jul 6, 2008 | 10:50 AM
RED99's Avatar
RED99
LINK
I would set it to it's lowest pressure and then about another 1 or 2 psi. Anything would be better than a 6-8 psi differential that I am getting now. I'm not 100% sure it's the fuel pump though after thinking out it. Because I thought it was from a low tank of fuel, but I remember filling up, and the pressue was the same. If it was fuel temp issue at the tank, then the fresh fuel should have cooled everything back down.
I think I may drill and tap the fuel rail and mount a mechanical gauge directly on the fuel rail and see if it jives with the electronic gauge. At least that will tell me if it's the gauge or not.
Old Jul 6, 2008 | 01:10 PM
corvettebob1's Avatar
corvettebob1
If it's an Autometer gage it's probably the sending unit, mine suddenly dropped 7 psi so I spoke with my tuner and he said they have replaced 7-8 sending units this year.
So I checked it with a mechanical gage and $100.00 later for a new sending unit it's back to 62 psi.
Old Jul 6, 2008 | 11:29 PM
leojnknsC5's Avatar
leojnknsC5
An air/fuel ratio gauge will tell you if your pressure is a problem or not.
Old Jul 7, 2008 | 12:28 AM
RED99's Avatar
RED99
It is an autometer.
To Fuel pressue issue
