Cog Pulley sizes
Old Jul 6, 2008 | 05:21 AM
SENNA forever's Avatar
SENNA forever
Default Cog Pulley sizes
Can anyone help me with Dia. sizes of the cog pulleys bellow:
27 Tooth
28 Tooth
30 Tooth
32 Tooth
73 Tooth
77 Tooth
Thanks for the help.
Old Jul 6, 2008 | 10:24 AM
Max@Cartek's Avatar
Max@Cartek
What's the pitch? Also what are you trying to figure out? Judging by the tooth count this is 8mm pitch.
If so this is how you do it for a rough sizing:
[(tooth count) X (pitch)] / (pi) = diameter in mm
Then to convert to inches divide that number by 25.4
If you are trying to figure out drive ratios then it's just the crank pulley tooth count divided by the blower pulley tooth count.
I hope this helps.
Max
Old Jul 6, 2008 | 11:39 AM
SENNA forever
Thanks Max.
The pitch is 8 mm as per your guess.
I am trying to figure out the diameter of these cog pulleys.
Sorry, but what does (pi) stand for on your formula?
[( 27 ) X ( 8 )] / (pi ???) = diameter in mm
I have a 8 Rib set up at present and want to change to a cog set up using the same existing ratios.
Old Jul 6, 2008 | 02:04 PM
stevieturbo's Avatar
stevieturbo
pi is pi....3.142
Old Jul 6, 2008 | 07:18 PM
makn u shiver's Avatar
makn u shiver
27 tooth - 68.75 mm or 2.7 inch diam
28 tooth - 71.3 mm or 2.8 inch diam
30 tooth - 76.4 mm or 3 inch diam
32 tooth -81.5mm or 3.21 inch diam
34 tooth-86.6mm or 3.41 inch diam
36 tooth -91.7mm or 3.61 inch diam
38 tooth -96.8mm or 3.81 inch diam
40 tooth-102mm or 4 inch diam
42 tooth 107mm or 4.2 inch diam
44 tooth-112mm or 4.41 inch diam
70 tooth-178mm or 7 inch diam
72 tooth-183mm or 7.2 inch diam
73 tooth -186mm or 7.32 inch diam
74 tooth-188mm or 7.4 inch diam
76 tooth-194mm or 7.64 inch diam
77 tooth-196mm or 7.72 inch diam
78 tooth -199mm or 7.83 inch diam
80 tooth-204mm or 8 inch diam
Old Jul 6, 2008 | 09:31 PM
Max@Cartek's Avatar
Max@Cartek
Originally Posted by stevieturbo
pi is pi....3.142
Old Jul 7, 2008 | 10:08 AM
SENNA forever
Guys, thanks for the info.
Got the exact information that was looking for.
To Cog Pulley sizes
