ECS meth question
Old Jul 20, 2008 | 12:42 AM
TurboTravis's Avatar
TurboTravis
Default ECS meth question
Noob question-what should happen when you press the test button?
Travis
Old Jul 20, 2008 | 01:03 AM
Chris Stewart's Avatar
Chris Stewart
It will activate the pump.
Old Jul 20, 2008 | 08:33 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It should stumble, because it is getting a shot of Meth and it gets too fat (Rich) and it makes it stumble.
It will clear as soon as you let go. Not enough air volume to fuel ratio and the Meth shot is after the MAF (Unless SD tuned) so it can't even try to compensate
Thanks,Matt
Old Jul 20, 2008 | 12:16 PM
FreddyG's Avatar
FreddyG
and the green light should come too.
Old Jul 21, 2008 | 01:27 AM
MPRTKLR's Avatar
MPRTKLR
Should it be green with the test button? My light turns red when I hit test, but is green when I go into boost. Maybe mine is just wired a little differently, who knows.
Old Jul 21, 2008 | 01:34 AM
TurboTravis
Is it 'safe' to test the system with the engine off for a split second, or should I do it while it's running and just listen/feel for it to stumble? I'm just fearful of the pump dying someday so I'd like to test it on a regular basis.
Old Jul 21, 2008 | 02:20 AM
FreddyG's Avatar
FreddyG
I looked in the instruction manual that Julio sent me and it just says that the LED should illuminate, but not a colo, so maybe neither of us is wrong. Maybe we just have different LEDs.
I just posted that because mine turns green.
Old Jul 21, 2008 | 07:39 AM
alzo6's Avatar
alzo6
if you turn the gain on your contoller, the ****, all the way up and hit test button it will turn green almost instantely.
Old Jul 21, 2008 | 09:01 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The light turns green when it has approximately 30lbs of back pressure on the nozzle. It could turn it to green with the test button if the system is turned way up. If the gain is really low then it will not pump much with the test button.
hope that helps.
Old Jul 21, 2008 | 11:22 AM
COALMINER,KY's Avatar
COALMINER,KY
Well this is interesting. Does the ecs meth kit come with a light system, ijust bought a procharger, and my tuner is ordering me a ecs meth kit. I have a 2 pod guage kit, shows fuel and boost pressure, I was wondering about a meth indication light, it would be very cool if the kit came with one.
Old Jul 21, 2008 | 12:30 PM
Julio's Avatar
Julio
Yes it does
When you press "Test" it simulates the same amount of alky that is shot in when it reaches its turnon point. Meaning lets say you run 13 PSI boost, kit activates at 4 PSI. At 4 PSI it activates with low pressure. When you press "Test" it puts out the amount the kit would at 4 PSI boost. Now if the controls are setup in such a way that lets say 20 PSI of alky pressure is shot when the kit activates.. then you will only see a "RED" LED condition. As the boost comes up from 4 PSI.. 5, 6, 7, etc.. pump spins faster, makes more pressure.. and when it crosses 30-40PSI pressure.. LED changes to green.
Typically if you place the **** on "8" and hit test, it will send out enough voltage to go red-green.
What does this mean.. if you have a wideband guage on your pillar.. and your cruising along 13-14:1 air fuel.. and you press test.. the air fuel will drop. Once it does, system is primed and loaded. So any change in air fuel, the alky is spraying. The colors just let you know a specific pressure has been met and gives a positive feedback.
MPRTKLR, working as should.
HTH
Old Jul 21, 2008 | 01:22 PM
FreddyG's Avatar
FreddyG
Originally Posted by Julio
Yes it does
HTH
Thanks Julio! I'll have to check mine out!
So should turn the gain down and hit the test button and see what happens? Have you always had the two colored LEDs because my kit is around 2 years old?
Old Jul 21, 2008 | 02:07 PM
TurboTravis
Thanks for the education on the system guys!!
Old Jul 21, 2008 | 02:18 PM
Julio's Avatar
Julio
Leave the gain alone. Watch for change in the way the motor runs when you press the button. If no change, then readjusting the gain will be needed. If you need further clarification, feel free to call.
Old Jul 21, 2008 | 08:17 PM
whitelite's Avatar
whitelite
I would always have the engine running
Bad things can happen spraying meth without engine running, why chance it?
Old Jul 22, 2008 | 11:17 AM
FreddyG's Avatar
FreddyG
Thank You!
Old Jul 23, 2008 | 01:37 AM
regorih's Avatar
regorih
good info here
To ECS meth question
