This should do the trick
Old Jul 22, 2008 | 07:50 PM
02402ramair's Avatar
02402ramair
Default This should do the trick
Later this year we are going for the C5 6speed world record. I finally bit the bullet and bought some goodies that should aid in the pursuit of the record. Here is a list and some pics of whats to come.
(1) Halltech ramair tunnel port (clean cool air to intake)
(2) poly rear suspension bushings
(3) Adjustable sway bar links
(4) Nitro Daves 90mm NOS plate system (200 hp) will be the first stage. Probably set it at 100 shot
(5) NX Direct Port NOS kit with 4 solenoids and upgraded rails (600 hp) will be second stage. will probably set it up at a 300 shot for 3 and 4 gear
(6) Line lock
I still need to do a gear change to run the 1/4.
Poly bushings
Tunnel port
90mm plate system
line lock and rails
NX direct port kit
I have enough nitrous to blow some **** up. lol
Old Jul 22, 2008 | 07:56 PM
02402ramair
I would like to thank Dave at Nitrous Daves for a killer deal on my nitrous setup.
Old Jul 22, 2008 | 08:17 PM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
looks killer but I just dont trust the funny gas
Old Jul 22, 2008 | 08:44 PM
02402ramair
I know most here are big FI guys. I thought hard about doing a Kenne Bell 2.8 on my stroker but decided I didn't want the headache of busted rear parts due to the massive torque off the line and all the belt issues that come with the blower setups. Most turbos have to much lag so nitrous was my choice. Most think its cheap HP but that's not the case if you run all the stuff to make it safe. I'm up to $5000.00 in nitrous equipment.
Old Aug 30, 2008 | 04:48 PM
02402ramair
Things are starting to come together. Next time I will let Nitrous Daves do the direct port install. What a bitch getting every nozzle exact, bending, drilling, flaring, and there is no room behind the intake for all this ****.
Old Aug 30, 2008 | 08:18 PM
zoomz's Avatar
zoomz
Very nice dude .
Good job on the install .
Old Aug 30, 2008 | 08:38 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
WOW!! You ain't messin' around are ya?
Old Aug 31, 2008 | 11:39 AM
02402ramair
Going for broke
Old Aug 31, 2008 | 12:51 PM
zoomz's Avatar
zoomz
I have 2 of those mills , just newer .
What year is that one ?
Old Aug 31, 2008 | 04:34 PM
02402ramair
I had a friend Doc Baker drill the holes in the intake. Its his mill so I have no clue to the year.
Old Aug 31, 2008 | 08:46 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Looks like lots of work! ! !
Old Aug 31, 2008 | 10:35 PM
02402ramair
You don't no the half of it. lol
To This should do the trick
