Novi 2000 Methanol Setup - ECS
Old Aug 3, 2008 | 09:48 PM
vet4fun's Avatar
vet4fun
Default Novi 2000 Methanol Setup - ECS
Looking for some help! Just received my 'modified' charge tube from ECS for methanol setup. The tube has 3 pre-drilled holes. I know one is the air temp sensor, and the other is the methanol injection. What is the third hole for?
Also got the separate air temp sensor & wiring harness for my '02. Which two wires do I clip from the MAF to wire in this new air temp sensor?
Old Aug 3, 2008 | 09:54 PM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
sounds like your air bridge is set up for the ECS dual alky nozzle kit
Old Aug 3, 2008 | 10:25 PM
vet4fun's Avatar
vet4fun
Ok, that helps. I thought I recalled hearing about a dual nozzle kit. I have the single nozzle. Thanks.
Old Aug 4, 2008 | 08:28 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Do not use the second nozzle if your not making enough power to support it.
To Novi 2000 Methanol Setup - ECS
