Nitrous Kits
Old Aug 5, 2008 | 07:08 PM
PerrinPhantomZ06's Avatar
PerrinPhantomZ06
Default Nitrous Kits
Looking to buy the most complete wet nitrous kit I can buy for stock c5 Z06.
Which Brand? I was Thinking NOS or Nitrous Express my two favorite choices by research. Who sells them. Ive been to alot of websites and am looking for something that maybe comes w/ the bottle opener and bottle warmer as a complete. Maybe this is ridiculous and i just need to order a kit and add a few things to it seperately. It be better if I could just get a full system with everything i wanted..
Ideas??
Websites?
Thanks In Advance
Old Aug 5, 2008 | 08:59 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
This site will be very helpful for you. LOTS of Nitrous guy's there.
http://ls1tech.com/forums/forumdisplay.php?f=10
I have the WET NOS plate kit set at a 150 shot. My local track is under going renovation, so I have yet to play with it.
Barely noticeable under the hood I like clean and neat.
10lb. Tank mounted in center compartment. I have not yet installed the bottle heater. I don't have a bottle opener since I will only use it at the track I will have time to turn the valve myself.
Beers Switch panel in the ashtray area.
Old Aug 5, 2008 | 10:05 PM
PerrinPhantomZ06
Very nice. Thanks for sharing
Old Aug 5, 2008 | 10:34 PM
algZO6's Avatar
algZO6
bob, very clean install. Per, i would go with a plate kit from nitrous outlet. they can set you up with everything you need. i personally run a tnt kit and have amazing results. do i little research and pick you poison, just do everything right and you will have a nice safe set up. ie: colder plugs, good tune, enough fuel, ect.
Old Aug 5, 2008 | 10:50 PM
PerrinPhantomZ06
Does anybody Know if they have a switch panel with switch for bottle opener aswell the ones that are already there?
And if I run colder plugs all the time but only run the nitrous some of the time how will the colder plugs effect my non nitrous performance and engine?
Old Aug 5, 2008 | 10:59 PM
16Again's Avatar
16Again
Contact the gentleman that makes them. Beer99C5 his name is Jim and he is a Supporting Vendor here.
http://forums.corvetteforum.com/member.php?u=196060
PerrinPhantomZ06;1566604346]Does anybody Know if they have a switch panel with switch for bottle opener aswell the ones that are already there?
As for your plugs, you will notice a minor performance loss which is more due to the timing you need to pull for the nitrous. I am running a big cam and did not notice any real performance loss.
To Nitrous Kits
