For you APS TT guys that drive your cars and use the A/C, have you noticed after stopping and shutting hte car down where the line condensation is dripping?? I can hear mine hitting a hot pipe somewhere and sizzling. Just wondering if this is going to be a cause for concern down the road somewhere.
It's probably hitting the passenger side turbine.
The drain is just above that area on the firewall.
I don't think it could ever be an issue since it's just water, and the turbines will eventually get surface rust anyway if they are not coated.
I would not worry.
That's what I figured, and I know if it was a pipe that they're stainless and shouldn't ever rust through. Just wanted to see if it was something I needed to head off or not.
